510 Bomber Posted October 17, 2011 Report Share Posted October 17, 2011 so i must post nothing but HELP posts. but i took my motor out. sealed it up. and put it back in. took WAAAAAYYYYYYYYYYYY to long. but i work alot. it was a great deal of fun and learning. sooooo my buddy took off my throttle cable without me knowing. and now when i put it back on, it just hangs. can someone take a pic of theirs for me? i have a L20b motor. would help me out alot. also pumpkn210 said theres an adjustment, but ill check that out in the morning. thanks for the help. I NEED THE BOMBER BACK ON THE ROAD!!!! Quote Link to comment
flatcat19 Posted October 17, 2011 Report Share Posted October 17, 2011 I'd kick said "friend" in the nutz. Quote Link to comment
Laecaon Posted October 17, 2011 Report Share Posted October 17, 2011 Are you talking about on the carb or at the pedal? What carb is it? oh and oics are great. Quote Link to comment
510 Bomber Posted October 17, 2011 Author Report Share Posted October 17, 2011 im holding the cable in place. Quote Link to comment
datzenmike Posted October 17, 2011 Report Share Posted October 17, 2011 That metal end just above your thumb is clamped to a holder that appears to be missing. Should look somewhat like this, although several types were used on the 620. In the picture below the screw and a small piece is missing that grips the cable end. Quote Link to comment
510 Bomber Posted October 17, 2011 Author Report Share Posted October 17, 2011 alrite, i found that part. it was in the pan i cleaned my motor over. put that part on. left my battery on charge. then cranked that baby over. it runs. buttttt........ it revs high, smokes from around the intake area.....and theres a knock when i drive it. well fuck. atleast it runs, i guess. now waitin for my bro to come home and he could help me out. Quote Link to comment
Laecaon Posted October 17, 2011 Report Share Posted October 17, 2011 What did you do to the motor? Valve adjust may be needed. Quote Link to comment
510 Bomber Posted October 17, 2011 Author Report Share Posted October 17, 2011 resealed it. it was leakin like a bitch. the rear main was the biggy. but it doesnt leak oil ne more. thats one good part Quote Link to comment
bananahamuck Posted October 17, 2011 Report Share Posted October 17, 2011 Does if over rev or just run fast.. maybe just your choke being on Or does it rev high without cable hooked up? maybe just mis adjusted Quote Link to comment
datzenmike Posted October 17, 2011 Report Share Posted October 17, 2011 alrite, i found that part. it was in the pan i cleaned my motor over. put that part on. left my battery on charge. then cranked that baby over. it runs. buttttt........ it revs high, smokes from around the intake area.....and theres a knock when i drive it. well fuck. atleast it runs, i guess. now waitin for my bro to come home and he could help me out. Choke on with fast idle or throttle cable not adjusted right.... make sure it has a slight bit of slack and isn't holding the carb open. Smoke is just oily hand prints or residual cleaner/splashed oil burning off.... it will go away. Knock, like a hammer hitting a hunk of wood or more like a sharp tap???? If it wasn't knocking before it shouldn't be now. Quote Link to comment
Guest kamakazi620 Posted October 18, 2011 Report Share Posted October 18, 2011 Choke on with fast idle or throttle cable not adjusted right.... make sure it has a slight bit of slack and isn't holding the carb open. Smoke is just oily hand prints or residual cleaner/splashed oil burning off.... it will go away. Knock, like a hammer hitting a hunk of wood or more like a sharp tap???? If it wasn't knocking before it shouldn't be now. He forgot to mention he used kitty litter in the oil pan to clean it THEN left it in there!!!!! Hahahahahahahaa and a green scotch brite pad!!!!! Quote Link to comment
510 Bomber Posted October 18, 2011 Author Report Share Posted October 18, 2011 well i belive i just start thinkin the worst when somehting happens. smoke was the cleaner smoking off,.....ima idiot. the knock, well it went away. but i do gotta repack my wheel bearings. the the over rev, well cable was to tight. so today i found out that my datsun runs. then i found out that ima idiot. and i didnt use kitty litter. just oven cleaner, gease lighting, scotch brite pad and wire brushes. hahha but holy shit, cant wait to drive around town tommrw showing off my DATSUN!!!! Quote Link to comment
bananahamuck Posted October 18, 2011 Report Share Posted October 18, 2011 Yeah we all over think stuff from time to time.......And it`s an old car, and old cars have weird problems sometimes. Quote Link to comment
510 Bomber Posted October 18, 2011 Author Report Share Posted October 18, 2011 im just so glad thats its back to running condition!!!! Quote Link to comment
