FiveSeventyZee Posted October 16, 2011 Report Share Posted October 16, 2011 So the I might be picking up an engine later today and the seller has a hoist which is good. but once up in the truck what do I put it on? can I just put it down kinda on its side? or is it better to put a spare tire under it? is there anything other than a spare tire that's just as simple If I can't find one? also once home I guess the same question. what do I put it on? just dangle it from a hoist? Quote Link to comment
Laecaon Posted October 16, 2011 Report Share Posted October 16, 2011 I drove my motor home on its side after draining fluids, it was in the trunk of my Jetta. Tires work well, but are bouncy as well, so straps might help. Hoist dangling can be fun, but not forever. I left my motor hung for a night, and then I needed my lift so I put the motor on a tire for a few days. My old motor is resting on wood blocks to keep it level. Sitting right on the oil pan, just make sure to support it well. As for long term storage of a motor... someone else will chime in... maybe since you didnt ask about it... Quote Link to comment
FiveSeventyZee Posted October 16, 2011 Author Report Share Posted October 16, 2011 oh so you can just rest it on the oil pan? as long as its well supported. and log term storage was the next question. I was linking put a little oil in the spark plug holes and crank the engine by hand a bit to coat the cylinders and then put the plugs back on to seal it. and remove the rocker arms so the valves all close. Quote Link to comment
Laecaon Posted October 16, 2011 Report Share Posted October 16, 2011 Well when a motor sits on a tire all the tire is doing is putting pressure on the oil pan. Yes I have rested my L18 on the oil pan directly on pavement. It held fine. So yes, just support it well, shouldnt be a problem. On my mercedes the oil pan was a jack point... and it never buckled! Quote Link to comment
Gary Posted October 16, 2011 Report Share Posted October 16, 2011 tyres are good ive used em lots they help stop the engine sliding about on the bed too :) once strapped down nice that extra friction makes sure it doesnt budge if you dont have any, your local tyre shop probably wont have a problem with you taking some old worn ones off their hands for free Quote Link to comment
dvboth Posted October 16, 2011 Report Share Posted October 16, 2011 on your way home stop and buy an engine stand! harbor freight has them for around $40, it gets the motor up off the floor were you can work on it and makes it easily moveable!! Quote Link to comment
Ken_B Posted October 16, 2011 Report Share Posted October 16, 2011 Heres my ratsun engine stand, motor mounts rest nice on the top rails and I have a wood block under the front of the oil pan, very sturdy actually and FREE! Quote Link to comment
Jayden71 Posted October 16, 2011 Report Share Posted October 16, 2011 wooden engine stand FTW!!! :lol: Quote Link to comment
flyerdan Posted October 16, 2011 Report Share Posted October 16, 2011 Shopping cart engine stand. They are low to the ground, very mobile, and available free on nearly every street corner in devolving third-world cities here. All you need to do is cut them up and reweld them in the proper configuration. Quote Link to comment
FiveSeventyZee Posted October 16, 2011 Author Report Share Posted October 16, 2011 Nice, and i work at a grocery store haha. but i dont have a welder....which causes problems Quote Link to comment
FiveSeventyZee Posted October 17, 2011 Author Report Share Posted October 17, 2011 Thanks for the responses guys. I got it home fine. right now I have it resting on an old tire and a 2x4. I think I will be either buying or building a stand so I can have it on wheels. next question: I know I can use my z 5 speed on the KA using a truck bellhousing but can I use the flywheel and clutch from my L18? I'm sure the answer is no but why not ask. also what throw out bearing and clutch fork do I use? the truck ones? is that already in my car since it was swapped to a 5 speed? Quote Link to comment
