Datsoon Posted March 26, 2008 Report Share Posted March 26, 2008 when I put my 4" blocks in the driveshaft bound. is this common , do I need to shorten my driveshaft? 3's seem to be ok but it is not enough for my taste. adjusted tortion bars about 3" no problem but I want to go lower, I realise I will have to cut down or loose the bumpstops and re-index the tortion bars. how low can I go? any insite would be appreciated. Thanks Quote Link to comment
]2eDeYe Posted March 26, 2008 Report Share Posted March 26, 2008 You can add spacers to the carrier bearing to help you driveline angles. I think 1" was about the right size spacer. Quote Link to comment
Bleach Posted March 26, 2008 Report Share Posted March 26, 2008 I used a 1.25 inch diameter box tube for a spacer. I had 3" blocks with a removed leaf. Should the similar to a 4 inch drop. on my kingcab I had no driveline issues. I hope it works for yours Quote Link to comment
Datsoon Posted March 26, 2008 Author Report Share Posted March 26, 2008 That makes sence. Ill do that . Thanks Quote Link to comment
Datsoon Posted March 26, 2008 Author Report Share Posted March 26, 2008 Thanks for the qick info. I would go 6" if I could but it looks like I might have to 4-link it for that type of drop. Quote Link to comment
Datsoon Posted March 27, 2008 Author Report Share Posted March 27, 2008 ok added a 2" block to the carrier, I will try re-installimg the 4" blocks tonight. I'll let you know how it turned out. Quote Link to comment
yello620 Posted March 27, 2008 Report Share Posted March 27, 2008 How low do you want to go? Quote Link to comment
yello620 Posted March 27, 2008 Report Share Posted March 27, 2008 That didn't show up how i wanted it to. Jason Quote Link to comment
]2eDeYe Posted March 27, 2008 Report Share Posted March 27, 2008 Looks good to me :D Quote Link to comment
Pacific coast Datsun Posted March 27, 2008 Report Share Posted March 27, 2008 I spaced my carrier up 1 3/4 inches. Obviously youll need to buy new grade 8 nuts & bolts.... i also raised my front shock towers 2 1/2 inches & installed new stock shocks [not in pic].... I then re-index'd the torsion bars, i still have suspension travel & it rides fine. Bump stops have been removed/tossed... Quote Link to comment
tyson Posted January 6, 2009 Report Share Posted January 6, 2009 ^^^that is a good idea with the shock towers, I'm not quite sure what you mean by re indexing the torsions? I will look for more info on that, that's a badass wink mirror you got in your truck, I still have one from back in the late 80's in the garage, lol Quote Link to comment
