what tires to use to strech on AP's 4 14s
  • Replies 24
.... WIDTH?..... 195 50s stretch on a 7" wheel pretty good, if you can hit it with alot of psi real quick. Looks realy dumb tho, they look ok on a 6"er
and 175's will fit too. It depends on how thick the sidewall is. I have seen a 175 that looked less stretched than a 195.
Holy shat they say that you can go with a 135 30 on my 8" wheels , it was hard for me to putt 195 50 on em at home, I ratchet strapped it and putt alot of air thru the bead before they hooked, it was ruff. I love the look of the 215 50 on 13x8s
You are doing it wrong. You need sudden explosion, kinda like how the 4x4ers remount their tires. Shops seems to use an old propane tank with a release valve. Fill it to about 90psi and let her rip into the gap of the tire and rim. For the DIYer though...
I tried 3 somewhat common sizes, at least I thought, nothing.
Cool idea though.
That site needs to be organized.
they don't do normal. They do stretch. And it is organized by wheel width then tire width tire profile rim diameter. They also only add what people send in I believe.
I'm pretty sure modifing a old propane tank would violate more OSHA laws than I count
I did say "seem" to use... what I saw in the videos was a white tank and a ball valve and a leaf blower hose at the end.
But ok it is a real device.
