NJJO Posted September 22, 2011 Report Share Posted September 22, 2011 sorry for the double post posted in wrong spot. looking for 2 intake valve for L20 with a U67 head code also need a Nissan Comp Head Gasket for the same engine. Quote Link to comment
datzenmike Posted September 22, 2011 Report Share Posted September 22, 2011 What's wrong with a regular 86mm head gasket for an L20B? You running an oversize bore or Z22 block? Quote Link to comment
banzai510(hainz) Posted September 22, 2011 Report Share Posted September 22, 2011 nissan has the 88.5 mm I have some 87mm from Baz in Australia Quote Link to comment
NJJO Posted September 26, 2011 Author Report Share Posted September 26, 2011 I'm Building a 40 over Z22 block with a L20 head, and am in need of a head gasket i was told a nissan comp head gasket is the one i need but if you think you have one that works then yes lets make it happen. Quote Link to comment
banzai510(hainz) Posted September 26, 2011 Report Share Posted September 26, 2011 nissanparts.cc enter in the blank M-11044-A7651 for the 88.5 mm gasket But contack Datzenmike, Sealick or Wayno for the headgasket mod(Byron510s) or look it up if possible. as they make holes in the block to get more water in there and mod the Napz gasket Quote Link to comment
Sealik Posted September 26, 2011 Report Share Posted September 26, 2011 Felpro...Z22/Z24 HG PN 9210 PT-1 8 holes drilled in block...actually 7, 1 is already there. Smaller holes....bottom row 9 holes in HG Which includes large oblong at back of head/block Quote Link to comment
