FiveSeventyZee Posted September 15, 2011 Author Report Share Posted September 15, 2011 yeah I checked that. just dropped the head off at the machine shop. it should be ready later tomorrow. that's great to hear about the fuel pump because I was a little worried for a bit Quote Link to comment
FiveSeventyZee Posted September 15, 2011 Author Report Share Posted September 15, 2011 Well bad news. my head has a hole from corrosion leaking coolant into the exhaust port. this is what caused my overheat and eventually head gasket failure. as of now my options are -continue with machining and weld the hole for $200-300 depending on if I get the valves done -find a new head -find a new engine seeing as I have time constraints finding a new head may not be the best idea as I don't see any for sale on my local craigslist. I have found a rebuilt L16 with a cam for $500. welding the hole up would get it to hold a seal but won't guarantee any time length that my head will stay suitable. this is because there are more areas of corrosion on the head and the same thing could happen again at almost any time. but would be the cheapest option at just under $200 if I bypass lapping the valves or if I do that myself. The problem I have with a new ngine is that I was hoping to swap to a KA at some point not too far off. so I feel like I could just do the bare minimum to get this engine back together and past the fix it ticket and hope that if/when this happens again I have a KA ready to go in as I was planning on buying a KA to rebuild and possibly build up while I continue to run my L18 anyways. Any advice from the rat gods? Quote Link to comment
banzai510(hainz) Posted September 15, 2011 Report Share Posted September 15, 2011 Your location is the United states but if we know where you live maybe by chance soembody has a L16 head you can have for cheap to FREE as thats what they go for. Quote Link to comment
FiveSeventyZee Posted September 15, 2011 Author Report Share Posted September 15, 2011 SF Bay Area...I guess I never put that in haha just north of SF actually I'm in Marin if anyone knows where that is Quote Link to comment
crackerjack69 Posted September 16, 2011 Report Share Posted September 16, 2011 Check our FS section for heads in your hood. If no, throw up a want ad on here, and explain your case. Good luck! All else fails, I see some L motor vehicles in the PicknPulls around you, go snag one. And Holy Cow, they got a pickup from '65 at one of your yards! Niiiice. Quote Link to comment
HRH Posted September 16, 2011 Report Share Posted September 16, 2011 A head hole shouldn't cost you $200 buck to fix. It should be all of 40-80 bucks to weld up and deck. Figure $300 if you're having all the valves and guides replaced. Quote Link to comment
