MikeRL411 Posted August 14, 2011 Report Share Posted August 14, 2011 Old NISMO catalogs give the following part numbers, may still be available or use for cross check. Two inch wheel studs and nuts: Front studs 40222-A0220 Rear studs 40222-H5020 Tapered nut for alloy wheels with tapered steel inserts or steel wheels 40224-R1120 Nut for Square shoulder alloy wheels 40224-E7200 Happy hunting, hope these parts don't cost more than you paid for the roadster! Quote Link to comment
youngen Posted August 15, 2011 Author Report Share Posted August 15, 2011 thanks you for the help, those lemans look sweet Quote Link to comment
Aclever1 Posted August 18, 2011 Report Share Posted August 18, 2011 Dave cover everything prety well. I just want to add that with a lower offset wheel the front will stick out past the front fenders quite a bit on most cars. I have a 70 with the wider fenders and a +17 to +22 offset on the front fits pretty flush. Also all my fenders we different. My rear were about 6mm different from each other and the fronts were almost 10mm. I had to order a bunch of different size spacers to get the right fit. 15x7 +32 3 piece Black Racing BR-R Falken 512's 185-55-15. Fronts 15mm spacers and rolled fenders rears 20mm spacers Front lowered on Super Comp springs powdercoated Red Barron Red. I know they look pinkish but they are red the 2nd to last picture looks to be more accurate in color. Quote Link to comment
JZ33 Posted September 4, 2011 Report Share Posted September 4, 2011 would some 14x7 with 0 offset fit his roadster? If so I have some and Im local so I could cut him a good deal if he likes them... Id like them to go to a fellow Datsun enthusiast haha Quote Link to comment
