rAwKStAh! Posted March 12, 2008 Report Share Posted March 12, 2008 Will 510 brake system fit onto a 521 pick up? what about the rear axle? i wanna turn my 521 p/u into 4 lug:confused: Quote Link to comment
]2eDeYe Posted March 12, 2008 Report Share Posted March 12, 2008 Why would you want 4-lug? I could almost see going to 5-lug, but.....6 lug rules. anyways, anything is possible.... Quote Link to comment
rAwKStAh! Posted March 12, 2008 Author Report Share Posted March 12, 2008 more wheel possibilities Quote Link to comment
LAYEDOUTB2K Posted March 12, 2008 Report Share Posted March 12, 2008 you do realize that a 510 is independent suspension and the 521 is a solid axle right? Quote Link to comment
MrRobatoGato Posted March 12, 2008 Report Share Posted March 12, 2008 http://forum.ratsun.net/showthread.php?t=2234&highlight=Independent+Rear+Suspension Quote Link to comment
WICKED JESTER Posted March 13, 2008 Report Share Posted March 13, 2008 you do realize that a 510 is independent suspension and the 521 is a solid axle right? the 510 wagon has a solid rear axel but it will not work in the truck unless you do some fabrication why not buy wheel adaptors 6 to 4 lug Quote Link to comment
Llittle_Llama Posted March 13, 2008 Report Share Posted March 13, 2008 the 510 wagon has a solid rear axel but it will not work in the truck unless you do some fabrication why not buy wheel adaptors 6 to 4 lug then offset would be an issue right? Quote Link to comment
]2eDeYe Posted March 13, 2008 Report Share Posted March 13, 2008 Depends on the wheels. Custom wheels come in various offsets. Quote Link to comment
Llittle_Llama Posted March 13, 2008 Report Share Posted March 13, 2008 2eDeYe;46092'']Depends on the wheels. Custom wheels come in various offsets. true, but their in lies $$$ Quote Link to comment
datsunaholic Posted March 13, 2008 Report Share Posted March 13, 2008 true, but their in lies $$$ Since he already stated the whole point was in custom wheels, that's not an issue. He isn't considering doing this to put 13" stock 510 wheels on. More of an issue in the original plan is the weaker axles. Might as well have the stock axles welded up and redrilled for 5-lug. Will require redesigning the brakes, but I can't see how someone would put a 510 rear in a truck and use those puny drums to begin with. Quote Link to comment
Llittle_Llama Posted March 13, 2008 Report Share Posted March 13, 2008 Since he already stated the whole point was in custom wheels, that's not an issue. He isn't considering doing this to put 13" stock 510 wheels on. More of an issue in the original plan is the weaker axles. Might as well have the stock axles welded up and redrilled for 5-lug. Will require redesigning the brakes, but I can't see how someone would put a 510 rear in a truck and use those puny drums to begin with. wow, and i though i was about to start a project, lol..... Quote Link to comment
