Head ID
lil89ram50
  • Replies 30
Well the one I had was supposed to be from a 200sx.Now the 200sx was a sort of 'sporty' car and may have come with them for higher compression.
200sx
The '78-'79 was # W5880 ... this head is used on the '78-'79 620 truck and it is definitely open and a W58
The '77 head was # N5800SV... this head is used on some 710s after Nov. 76 but the L20B also used the U67 and the W58
The A10 (HL510) used the W5880 head and the 610 only used the U60 and U67 head. Maybe N5800SV means peanut???
SV i believe means it is service part, not a production line fitting.
In the late 70s nissan had closed chamber and small ports for A-series too. The open chamber head lowers NOx, but instead they used a lot of EGR to lower the NOx. At the same time they continued to open chamber/large port heads. Two different ways to do the same thing. Either rev it up or make it work at lower RPMs.
