skyknight789990 Posted August 8, 2011 Report Share Posted August 8, 2011 with your trans, ya. your going to have to drop the trans and pull it apart to see the gears. damn i was hopping i didnt have to my truck is lowered 6 inches ok thanks i am gonna try an hobble it to my buddys Quote Link to comment
datzenmike Posted August 8, 2011 Report Share Posted August 8, 2011 sounds like someone got this figured out my 79 620 did the same thing today but i am stuck in 3rd can anyone help me Does the shifter move out of 3rd, or is it stuck as well? Quote Link to comment
skyknight789990 Posted August 9, 2011 Report Share Posted August 9, 2011 got the tranny out an got the back cover off an was looking at the internal linkage set up an it was not in line i think the tongue that go in between the fork like cut outs in the ends got above the reverse linkage an was still in 3rd so it blocked it self from going into any of them i ended up lining them up an put it back together an tested it 3 times before putting it back in the truck an worked fine drives fine now just lost to how it got that way all 3 linkages are stiff to move by hand with out the shift lever but its fine now Quote Link to comment
datzenmike Posted August 9, 2011 Report Share Posted August 9, 2011 Hmmm if it can happen once it can be repeated. Hopefully not. Was it a four speed? The shifter linkage is slightly different than the 5 speed. . Quote Link to comment
skyknight789990 Posted August 9, 2011 Report Share Posted August 9, 2011 yes it is a 4 speed Quote Link to comment
