AZhitman Posted June 29, 2011 Report Share Posted June 29, 2011 Anyone know if they're the same as 311 mounts? Mine are SHAGGED. Lumpy cam and U20 crank is making my stroker motor do the hula. :) Link to comment
MikeRL411 Posted June 29, 2011 Report Share Posted June 29, 2011 In the worst case you might have to look up a tire recapper and see if they could vulcanize new rubber into your existing mounts. I wish you good luck in finding new ones though! Link to comment
AZhitman Posted June 29, 2011 Author Report Share Posted June 29, 2011 Mike - I take it they're not the same as 311 (or 520)? Link to comment
MikeRL411 Posted June 29, 2011 Report Share Posted June 29, 2011 Mike - I take it they're not the same as 311 (or 520)? I really have no idea about 311 mounts. But since the 411 front crossmember is different, the lower points where the mounts attach may well be in a different location. Tana [Vindats1] may have the answer, she has both Roadster and 411 parts. By the way, check your transmission mount, it will be taking a beating also. Link to comment
RATDAT3 Posted June 29, 2011 Report Share Posted June 29, 2011 gcmustang (Greg) probably has some or the answer to your question. Link to comment
gcmustang Posted June 29, 2011 Report Share Posted June 29, 2011 Greg, PM me your phone # and I can tell you my thoughts. I have looked @ roadster motor mounts and they can be made to work. GCMUSTANG/Greg Link to comment
MikeRL411 Posted June 30, 2011 Report Share Posted June 30, 2011 If roadster mounts can be made to fit, try to get the 2 liter engine mounts, due to all the mods you made to the engine they would probably be of the right shore hardness to take the vibration. Link to comment
ppeters914 Posted July 1, 2011 Report Share Posted July 1, 2011 (edited) Just looked it up. First off, the roadster 1600 (R16) and 2000 (U20) use the same mounts, and the same part fits left & right sides. It's still available from Nissan. Think they cost me approx $25 two years ago: ASSY-INSULATOR, ENGINE MOUNTING, FRONT: 11223-32200 Unfortunately, the 411 R16 has a different part number for the left & right: ASSY-INSULATOR, ENGINE MOUNTING, FRONT (R.H.): 11222-15801 ASSY-INSULATOR, ENGINE MOUNTING, FRONT (L.H.): 11223-15801 No idea if those are still in system. Have emailed parts check request to Datsun-friendly parts guy. Sorry. Parts guy says NLA. Edited July 2, 2011 by ppeters914 1 Link to comment
pl521sss Posted July 1, 2011 Report Share Posted July 1, 2011 Anyone know if they're the same as 311 mounts? Mine are SHAGGED. Lumpy cam and U20 crank is making my stroker motor do the hula. :) Dude I just sold NOS R16 motor mounts not long ago!!! Link to comment
erichwaslike Posted July 1, 2011 Report Share Posted July 1, 2011 i may have a used set. i can check next week. Link to comment
