510 Tachometer differences
  • Replies 18
Mine is wired to the negative side of the coil. Just disconnect the wire going to the negative side, hook up on of the wires from the tach to it and then hook up the other wire from the tach to the negative coil post. If it doesn't work, reverse the 2 tach wires. I have done quite a few 4 wire tach installs and all of them are wired this way.
Success! I tried ^^^ the method quik510 uses.
The cluster looks so much better with the tach there.
Thanks everyone.
  • 4 months later...
