wildmaninid Posted June 17, 2011 Report Share Posted June 17, 2011 Just wondering if anyone has any formulas or has converted any factory datsun paint colors over fo basecoat/clearcoat? I have code 019. Wich is sunshine yellow, on my 77 620......when I look up the code on dupont catframs all I get are formulas for single stage paint......not happening. So yea if I have to pick another color close I will but would reallllly like to keep it stock. Quote Link to comment
metalmonkey47 Posted June 17, 2011 Report Share Posted June 17, 2011 Go to a bodyshop that sells paint, give them color code, and get the paint Friend had the stock color on his 76 Ford Torino replicated exactly. Quote Link to comment
wildmaninid Posted June 17, 2011 Author Report Share Posted June 17, 2011 Nice idea, but I mix my own paint, and get a smokin deal, not into getting grossed at a body shop. Quote Link to comment
albyneau Posted June 17, 2011 Report Share Posted June 17, 2011 Nice idea, but I mix my own paint, and get a smokin deal, not into getting grossed at a body shop. Does that mean you squirt your own as well? Have something custom in mind, or a reason why you can't squirt clear over your yellow? Quote Link to comment
wildmaninid Posted June 17, 2011 Author Report Share Posted June 17, 2011 yes I paint as well. All paint has a formula to mix up. When I punch in the code on my computer, all I get codes for are single stage paint. This paint has the chemicals in it that make it glossy in one step, hence single stage, you paint it, it gets glossy, bam you are done. I fucking hate spraying single stage, so I am asking if anyone had found formulas to mix up these colors in basecoat, which sprays in two steps...the base will be very dull when sprayed, and the clear will give it the gloss. You cannot spray clearcoat over single stage paint for a variety of reasons that I will not delve into here. I can spray any color I can find a formula for, I would just like to try to keep what I have if possible Quote Link to comment
Wide14u Posted June 17, 2011 Report Share Posted June 17, 2011 im to lazy for more then 1 stage of painting :D 2 Quote Link to comment
wildmaninid Posted June 17, 2011 Author Report Share Posted June 17, 2011 +1 for laziness! 2 Quote Link to comment
Wide14u Posted June 17, 2011 Report Share Posted June 17, 2011 i spent the half the day rolling mine but i used the 3 ' rollers to get a nice coat on it :rofl: 2 Quote Link to comment
wildmaninid Posted June 18, 2011 Author Report Share Posted June 18, 2011 You were rollin something alright. Quote Link to comment
datsunwizard Posted June 18, 2011 Report Share Posted June 18, 2011 You can spray clear over single stage, have done it a lot, you must scuff between the color and the clear. Here some examples: Clear sprayed on after the graphics where put on. This was cleared with what I call dish water, clear mixed with some color, looks cloudy in the can, sprayed two coats, then color sanded, then two coats of straight clear. The dish water creates depth. Quote Link to comment
wildmaninid Posted June 18, 2011 Author Report Share Posted June 18, 2011 Cool, I am not going to be doing that.......Single stage paint evaporates solvents for months after it is sprayed, which is what hardens the paint and give it the shine...........spraying a clearcoat over it traps those solvents under another another layer of urethane, with its own solvents than need to evaporate.........Not trying to be a dick, but I am not interested in trying to be schooled on how to paint, I have been doing it for enough years that I have quite a firm grasp. BTW I converted the formula myself and mixed up my basecoat yesterday. Quote Link to comment
Wide14u Posted June 18, 2011 Report Share Posted June 18, 2011 so when are you going to shoot yours Quote Link to comment
wildmaninid Posted June 18, 2011 Author Report Share Posted June 18, 2011 Got the new rust free fenders prepped, and i am just gonna squirt them......then this fall the rest of the bodywork will be finished so sometime before thanksgiving. I dont want to take the truck out of comission during the summer driving months. Quote Link to comment
Radiant-Designer Posted October 18, 2011 Report Share Posted October 18, 2011 Any way you can share some info on this. I am looking to paint my 620 as well. the paint number is rubbed off, so I think it was either a 019 or 102 (from what I searched) its a 77 620 if anyone can help me out on that would be great. and if you figured out how to go from single stage to two stage please share! Quote Link to comment
DanielC Posted October 18, 2011 Report Share Posted October 18, 2011 So, let me see if I understand you. You mix your own paint. You want to duplicate in base coat/clear coat a color that was originally a single stage factory color. Problem one, the original color had changed or faded over time. But you know that. Problem two, BC/CC will have a different color than single stage. This is what I would do, if I really wanted it to get close. This is not the process a body shop would do, trying to beat a flat rate. If you have a good original panel on the vehicle, wash, and then buff it, to get faded old paint off, and get to the original color. Do not buff so thin, the primers start to show through. If you do not have the original paint intact, you might have to buy a small quantity of the factory color in a single stage, and spray that, and use that as your color standard. You mix your own paint. Custom make a small batch of base coat, to the color you are trying to get. Take careful notes of the mix ratios, spray gun settings, and any other factors that affect paint you can think of. Spray it on a test panel, clear coat it, and compare the color back to the original. Make a slight change in the custom mix you feel is appropriate, again taking careful notes, and make another test panel. Compare back to the original, and the changes, and make another custom mix, and spray it. When you get tired of trying to match, or get it close enough, make a big batch of paint, and spray the car. Keep in mind, if you are working with a metallic paint, the spraying technique will greatly affect the color. Quote Link to comment
