roostersdad521 Posted June 5, 2011 Report Share Posted June 5, 2011 is anyone running toyota truck suspension on a 521? Just wondering how involved it would be... Quote Link to comment
Jayden71 Posted June 5, 2011 Report Share Posted June 5, 2011 :o :huh: <_< :confused: :no: whats wrong with the suspension you got naow? Quote Link to comment
thisismatt Posted June 5, 2011 Report Share Posted June 5, 2011 :o :huh: <_< :confused: :no: whats wrong with the suspension you got naow? Kingpins, drums, torsion bars (okay, that's toyotas too, but still)...? I don't plan to do a yota front end, but I am going to be putting a yota rear axle into mine - 3 inches wider (will fit the higher offset wheels I have perfectly), self adjusting drum brakes, gearing options out the wazoo, and I just bought a 4.10 geared limited slip 3rd member for it for $175 shipped. Good luck finding anything posi/lsd/locker/torsional for the stock 521 axle! Still 6 lug, too. Quote Link to comment
kezark31 Posted June 7, 2011 Report Share Posted June 7, 2011 there is a bagged 521 named "ethel" running a toyota front clip its on here somewhere Quote Link to comment
Z chopper Posted June 11, 2011 Report Share Posted June 11, 2011 Get an LSD with disk brakes from a pathfinder (i think d21 hardbody also) which I think there are gearing options out the wazoo available aswell Quote Link to comment
flatcat19 Posted June 12, 2011 Report Share Posted June 12, 2011 Get an LSD with disk brakes from a pathfinder (i think d21 hardbody also) which I think there are gearing options out the wazoo available aswell That's a wide diff. Even wider than a Yota axle, and wider than a stock 521. Quote Link to comment
bagged320 Posted September 5, 2011 Report Share Posted September 5, 2011 twisted minis did the ethel 521, came out nice, check out twistedminis.com under forum for build pics, also some vid on you tube I think Quote Link to comment
