pocket rocket Posted June 4, 2011 Report Share Posted June 4, 2011 Wanted; Edelbrock or Offenhauser intake manifold, to suit L4 engines & accepting Holley 2 barrel carb (2300 series). Offenhauser part numbers would be; 6213C or 6214C with a 6231 adapter. Not interested in the dual port style manifolds!!! Link to comment
Dirttrack510 Posted June 4, 2011 Report Share Posted June 4, 2011 I don't have one for sale, but I have one that I bought for my race wagon. I thought you might like photo to use for your ad. I LOVE MINE!!! Weber 40DFAV1 bolted right on as does a 32/36. Link to comment
pocket rocket Posted June 10, 2011 Author Report Share Posted June 10, 2011 Bump to the top. Dirttrack510's photo is what I'm looking for, or Offenhauser's version Link to comment
pocket rocket Posted June 23, 2011 Author Report Share Posted June 23, 2011 BTT Dirttrack 510 - you want to sell yours? maybe give you the opportunity to move up to a single side draft weber/delorto (or similar) or to twin carbs Link to comment
dryheat Posted June 27, 2011 Report Share Posted June 27, 2011 There is an Offy manifold on Phoenix Craigslist ... not sure if it is the one you are looking for Offy Link to comment
pocket rocket Posted June 28, 2011 Author Report Share Posted June 28, 2011 Thanks for that. Unfortunately that isn't the one. That is one of the "dual port" versions, with a divider in the intake runners. I'm really after one of the intakes that don't have these. If I knew how far into the manifold these dividers went, it might be possible to mill them out (if they didn't go to deep). But I'm trying to avoid buying one, just in the hope that I could do that. Link to comment
datsunfreak Posted June 28, 2011 Report Share Posted June 28, 2011 That is one of the "dual port" versions, with a divider in the intake runners. I'm really after one of the intakes that don't have these. If I knew how far into the manifold these dividers went, it might be possible to mill them out (if they didn't go to deep). But I'm trying to avoid buying one, just in the hope that I could do that. Pretty sure they go all the way up to the carb? At least the one I used to have did. As I recall, the idea was to completely separate the primary barrel from the secondary barrel in the intake tract. Supposed to help torque (small runner for low end, big runner for top end). Link to comment
wildmaninid Posted July 16, 2011 Report Share Posted July 16, 2011 Dang I have a dual port one fs.... Link to comment
pocket rocket Posted July 18, 2011 Author Report Share Posted July 18, 2011 I've never seen one (D/P) first hand. Think there is any chance the port dividers could be machined/ground out? without cutting the manifold in half Link to comment
datzenmike Posted August 3, 2011 Report Share Posted August 3, 2011 Pretty sure they go all the way up to the carb? At least the one I used to have did. As I recall, the idea was to completely separate the primary barrel from the secondary barrel in the intake tract. Supposed to help torque (small runner for low end, big runner for top end). Sounds good in theory but in practice the smaller primary, while forcing the air to flow faster, dumps into the huge intake port in the head and immediately slows down. Most gains are lost. The cross sectional area of the intake runner has a huge divider in there taking up space. You would think that one large runner would be better for top end. Link to comment
Dime Dave Posted August 4, 2011 Report Share Posted August 4, 2011 Below is an old Offenhauser catalog page with the Datsun 2 barrel manifolds. It would appear that you are looking for a "C Series" manifold. Looks like the P/N's are 6211C, 6212C, 6213C, 6214C or 6215C. The ones with the "CW" sufix are the 32/36 Weber carb pattern. I beleive I may have a "CW" manifold with a canted home made adapter to fit the 5200 Holley that I would sell. I will have to dig it out and take some pictures. Link to comment
pocket rocket Posted August 5, 2011 Author Report Share Posted August 5, 2011 Would definitely look at that. Yes the "C" manifold is what I was looking for. Link to comment
Dime Dave Posted August 8, 2011 Report Share Posted August 8, 2011 Here is the manifold and adapter I have. Looking for $150USD + S&H. Link to comment
pocket rocket Posted August 9, 2011 Author Report Share Posted August 9, 2011 whats with all the silicone sealant under the carburetor flange? Link to comment
Dime Dave Posted August 9, 2011 Report Share Posted August 9, 2011 whats with all the silicone sealant under the carburetor flange? I do not know what the silicone is for. I didn't figure it was important as the adapter isn't really worth anything as is because it tilts the carb. The car it was used on was a circle track mini modified. They installed the engine sitting straight up, not tilted to reduce left side weight. The adapter comes with the manifold, for good or for bad. I suppose it could be modified for a standard engine tilt. I figured the pictures would be good enough to show what the adapter was and you could deside if it was something you wanted to mess with or toss. The $150 asking price is really for the manifold only. The adapter is free and you can do with it as you'd like. Sorry that I didn't take the time initially to explain that the adapter was for an engine install at a non-stock angle and would likely be of little use as is. Link to comment
