Dimerforlife13 Posted June 1, 2011 Report Share Posted June 1, 2011 Is there anything bigger than the 88.5? My bore is gonna be 89.5 (lz23) just wanted to make sure before I talk to some parts guy who doesn't know what he talking about. Thanks in advance. Quote Link to comment
datzenmike Posted June 1, 2011 Report Share Posted June 1, 2011 Z24 and KA24E are 89mm but the front's are different and they will likely need holes opened to match an L head. Sealick on here has been working on this. Quote Link to comment
MikeRL411 Posted June 1, 2011 Report Share Posted June 1, 2011 The 1997 NISMO parts catalog lists part number 11044-NR431-1 for 90 mm max bore diameter. Compressed thickness 1.5 mm. Close enough? The full competition gaskets with O-ring to be machined into the block only fit up to 88.8 mm. Too small and too damned hard. Quote Link to comment
Sealik Posted June 1, 2011 Report Share Posted June 1, 2011 I used the Felpro 9210 PT-1.....Z22E, Z24I, Z24S app. Approx..91.3mm Drilled 9 holes in HG...and 7 in block There will be 2 tabs of the HG that hang over the TC cover....cut them flush. One will fill/fit the void on the left front corner, where the HG doesn't reach. Quote Link to comment
Sealik Posted June 1, 2011 Report Share Posted June 1, 2011 The 1997 NISMO parts catalog lists part number 11044-NR431-1 for 90 mm max bore diameter. Compressed thickness 1.5 mm. Close enough? The full competition gaskets with O-ring to be machined into the block only fit up to 88.8 mm. Too small and too damned hard. Thought that Nismo HG was just for the LZ22 app??? Quote Link to comment
hang_510 Posted June 2, 2011 Report Share Posted June 2, 2011 Thought that Nismo HG was just for the LZ22 app??? just? its an L series HG. its the best though. i still had to make 1 hole in it. the Z24 would be the easiest Quote Link to comment
Sealik Posted June 2, 2011 Report Share Posted June 2, 2011 just? its an L series HG. its the best though. i still had to make 1 hole in it. the Z24 would be the easiest Ya....I know they're for the L series.... :) For some reason I thought they were only good up to the LZ22...not for the larger LZ23. Getting real close to max allowable bore though. 1 hole in HG....assumed you drilled some in the block? Not sure what the Nismo HG looks like....coolant passages and all. Quote Link to comment
