wana510 Posted June 1, 2011 Report Share Posted June 1, 2011 Need the complete set up including hoses prefer new but will take used as long as its fully functional and all intact. I need everything bought a 510 with no rear brakes at all. Let me know a price shipped to 77568 Link to comment
72dyme Posted June 1, 2011 Report Share Posted June 1, 2011 You can get most of the parts new online or at your local auto store. Link to comment
datto510 Posted June 1, 2011 Report Share Posted June 1, 2011 do you have the backing plates? Link to comment
DREWSDIME Posted June 2, 2011 Report Share Posted June 2, 2011 Probably better to go with disc in the rear since you have no brakes at all. You can find someone selling bracket to do disc conversion in rear using 240sx brakes or 200sx. I could sell you a used rear drum setup but your gonna have to rebuild it. By the time you buy used setup and get new parts to rebuild for a little extra you can get disc brakes. Depends on what you want to do? Link to comment
zerow Posted June 2, 2011 Report Share Posted June 2, 2011 Some of those drum parts are nearly non-existent... Try asking for the springs and hardware kit for that 510. Just like my 610, NLA... Like DREWSDIME said, go disc in the rear. I sourced everything for mine and have all new parts and spent about $400. You said you have nothing? Do you have the rear control arms? I only ask because if you have the arms, but the backing plates were brutally removed, it sounds like it was already underway for the disc conversion sometime in its life. Better to go that route than add good money after bad, as the backing plates can ONLY be installed if you remove the bearings, seals, and locknuts (adding another $150 to the number above :o ) Link to comment
Chris#51EPGraham Posted June 2, 2011 Report Share Posted June 2, 2011 I have a pair of 510 sedan rear drums and very rusty backing plates that would be ok sandblasted and repainted. Also have some adjusters and probably the spring hardware, all used. I have used sedan rear cylinders that are strictly rebuildable cores. If rear flex lines are NLA, the easiest solution is to buy stainless Aeroquip type lines from Pegasus Racing. They'll have correct end fittings available in custom lengths. Link to comment
wana510 Posted June 4, 2011 Author Report Share Posted June 4, 2011 There is a rear disk conversion complete setup on ebay for 600 I think ill do that Link to comment
DREWSDIME Posted June 4, 2011 Report Share Posted June 4, 2011 You can also by just the bracket to disc brake conversion for about $100-$150 then you just need some calipers, rotors and brake lines. Im sure you could get that number closer to $300 if you got some used calipers and e brake lines, and new rotors and brake hoses. Depends on what your planning on doing? $600 seems like alot to me for some regular rear disc. i think you can get a wilwood setup for that price? Link to comment
DREWSDIME Posted June 4, 2011 Report Share Posted June 4, 2011 I just remembered I saw the 5anddimegarage has wilwood brake setup for rear ready to bolt on $500 for the rear and $700 for the front Link to comment
hang_510 Posted June 5, 2011 Report Share Posted June 5, 2011 Try asking for the springs and hardware kit for that 510. Just like my 610, NLA... 280Z's w/rear drums use the same hardware. Link to comment
zerow Posted June 5, 2011 Report Share Posted June 5, 2011 280Z's w/rear drums use the same hardware. Really? Well, I could have saved a couple bucks with that knowledge...Oh well, I have discs already set up for the 610. Link to comment
Drive510 Posted June 3, 2012 Report Share Posted June 3, 2012 I know it's been a year but do 13's fit with the rear disc conversion? Link to comment
DREWSDIME Posted June 3, 2012 Report Share Posted June 3, 2012 I dont think so. Maybe 14 with some setups Link to comment
banzai510(hainz) Posted June 4, 2012 Report Share Posted June 4, 2012 try rock auto.com or importrp.com has the Brembo made ones last time I cked Link to comment
