Sinnful Posted May 20, 2011 Report Share Posted May 20, 2011 if its that spendy down in so cal, send me your ignition and I think jsut to have a key made its only like 30.00 so whatever let me know Quote Link to comment
Shagy Posted May 20, 2011 Author Report Share Posted May 20, 2011 I'll let you know. I got an email back from a guy that for $29.95 and my key code says he can cut one. So I might go that route. Seems like a fair price. I mean, if the code tells you how and where to cut, it shouldnt be that hard......right? Quote Link to comment
Sinnful Posted May 20, 2011 Report Share Posted May 20, 2011 Yeah it should be good Quote Link to comment
Shagy Posted May 21, 2011 Author Report Share Posted May 21, 2011 $21 dollars later and I have 2 keys that work al the outsie locks. I think there is something in the ignition, the key wont go in all the way. I tried to pul it off the colume but I didn't have the right tools with me. I went to roca lock & key in LA. 5729 Whittier blvd. Right next to A&G audio. Girl named Carla. 323.888.6666. Only took 10 min. Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 So where is the code on the ignition? Do I have to disassemble it? The key is slding in now...but won't turn. Id like to verify the code. Quote Link to comment
darrel Posted May 22, 2011 Report Share Posted May 22, 2011 usual rate,, about $15 for one key cut to code. extra key less than $5. The BS about out of date codes, again BS just trying to gouge you. They could rekey cylinders and ignitions, for that it may be $30 per lock. Maybe more for ignition lock because drilling might be required, if my memory serves me correct. Chances are, the ignition may have been replaced and it had an updated cylinder which had the reversed key blank. Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 If it had the reversed blank the key should not go in...right? I don't think its the X7 blank. The doors are X6. Both doors and hatch wor now. I lubed the ignition and got the key to go in...based on what I saw with the switch taken off, the ignition is in the "on" position. Btw...lights, turn signals & brake lamps work :) Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 But this still leaves me unable to see a code on the ignition....where is it? Quote Link to comment
ggzilla Posted May 22, 2011 Report Share Posted May 22, 2011 There is no code on the ignition. It's one key code for all three. Even the wrong key should go all the way in, but won't unlock the column. If if goes halfway in , there's something blocking it in the cylinder barrell, dirt maybe. haha, i unlocked my mom's 1996 crown vic the other day and started the engine. Then she hands me the key. Turns out my 1994 Mazda pickup key is a perfect match! Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 Then I guess 2 things... 1 - the ignition is NOT the same as the doors IE it was changed out at one time (like posted above). 2 - The tumblers are just stuck and I still need to soak them. The key DOES go in all the way now. I believe its in the "ON" position, but if thats the case, then I should not be able to take the key out, unless something is broken. The colume lock will not engae. I brough the ingnition home with me to see if I can get it to work. Quote Link to comment
ggzilla Posted May 22, 2011 Report Share Posted May 22, 2011 With many Datsun ignition cylinders, you can remove the key from the ON position. Even when nothing is broken. Mine works that way probably because it is worn a bit. Other Datsun key's don't work in mine, so functionally the cylinder works. Still I can pull the key out when the engine is running. Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 I see. I'm working with NEW keys. Maybe the tumblers are just stuck.....Its been sitting for about 5 hours with WD40 in it..I might go and try it again. I really want it to work. Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 How do you get to the tumblers in the ignition? Quote Link to comment
hogboy52 Posted May 22, 2011 Report Share Posted May 22, 2011 To release the ignition tumblers take some stiff wire and bend a small hook in the end. Insert the wire all the way into the lock and push upwards and pull the cylinder out. there is a brass slider at the rear that holds the cylinder in place. Tape the cylinder to keep the small brass tumblers from falling out. The brass tumblers are numbered from 0-5 and if the lock is for a different key it is possible to shift the tumblers around to get the closest fit and then file down any that sticking up a bit. Quote Link to comment
darrel Posted May 22, 2011 Report Share Posted May 22, 2011 Here is a very detailed thread on nissan deisel. It should answer all your questions regarding the ignition cylinder. http://nissandiesel.dyndns.org/viewtopic.php?p=7115 Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 Do I have to remove the trim ring that has "on, acc.." on it? Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 darrel...thanks for that link. I hit a wall. I have it ready for the cylider to come out...but there is something keeping it in. I think it ahad to do with the cylinder doing in "on" and not letting this bar move down. I can get the cylinder out almost a 1/4"...but then it stops. I don't want to force it. Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 So I moved the "key in" reminder and the thing slid out...hopefully if I take this to the locksmith guy he'll be nich and just re key it... Quote Link to comment
darrel Posted May 22, 2011 Report Share Posted May 22, 2011 Do you have the wafers exposed? If you do, you can clean it out and get the wafers unstuck then put the key in to check which are too high. If all the wafers move freely, when you put the key in, all the wafers should be flush. If they aren't then the ignition key is different than the rest of the locks. Quote Link to comment
Shagy Posted May 22, 2011 Author Report Share Posted May 22, 2011 Well slap my ass and call me bob....ITS THE SAME KEY!!!! I think there was something sticking. I took the cylinder out, cleaned the out housing, lubed the back and put it all back together. It all works. Now if I could get the motor to unlock so easily! Quote Link to comment
Shagy Posted May 23, 2011 Author Report Share Posted May 23, 2011 From yesterday.... Quote Link to comment
screamer510 Posted January 22, 2012 Report Share Posted January 22, 2012 Sorry to bring up the past, but... Does anyone have a Taylor key for a 510 door and trunk with a number on it? Mine looks like the shorter one on the left on the first page. My local place has over 1000 keys, but couldn't match it in their books. I did get an ignition switch key, it must've been replaced at some point. Sorry again, just looking for some help. Dan Quote Link to comment
ggzilla Posted January 22, 2012 Report Share Posted January 22, 2012 510 double-sided key * Nissan KEY00-00036 $7 * Nissan KEY00-00037 $7 * Nissan KEY00-00056 $8 * Taylor X6 510 single-sided key: If you have the single-sided type, there were a bunch of them, depending on the year of the 510. Quote Link to comment
ggzilla Posted January 22, 2012 Report Share Posted January 22, 2012 Oh by the way, I have two Nissan ones uncut, will sell 2 for $12 shipping included. Check the right-handedness of what you need: 2nd groove is LEFT of center groove 2nd groove is RIGHT of center groove << this is what I have Quote Link to comment
screamer510 Posted January 22, 2012 Report Share Posted January 22, 2012 Single sided Quote Link to comment
