OMGNOWAI! Posted May 14, 2011 Report Share Posted May 14, 2011 i've got su's waiting to be slapped on to my motor, but i haz ball joint linkage to a 32/36 weber which simply wont reach with the su's. however, i did buy for 3 DOLLARS a bicycle brake cable that has the length i need. now i just needa sleeve and figure out a plate and adjustment deal for it. this is where ye olde ratsun comes in. throw me some ideas on what to look for thats not a 50 dollar lokar cable so i can quit fiddling around with this puny weber. the sleeve doesn't concern me so much as the cable adjustment idea, having had a throttle cable made of shoe lace before (yes my chuck taylors are laceless now because of a datsun at one point) the idea of ghetto is already nothing new to me. HELP PLZ! THANKS Quote Link to comment
ggzilla Posted May 14, 2011 Report Share Posted May 14, 2011 Here's a no-buck idea, it worked on my 32/36 back in the day, maybe you can do something similar The factory twin Hitachi setup should already have a single point of connection for both carburetors. If your using a non-factory setup, what does it look like? Quote Link to comment
]2eDeYe Posted May 14, 2011 Report Share Posted May 14, 2011 Most excellent cludge. :lol: Quote Link to comment
Spades Posted May 16, 2011 Report Share Posted May 16, 2011 if you have no metal working skills or air tools, but don't want something that looks too hokey, use galvanized strapping(also referred to as plumbers tape). Use a very heavy gauge, and the only tools you will need for decent looking results are a hacksaw, pliers, and some time. The stuff can be used to make brackets with, and if you get strong enough strapping and use a double layer for strength(or anchor the bracket in multiple places), you can make a permanent bracket that doesn't look too hokey (without needing a welder, a torch,air tools, or a vise). Quote Link to comment
jesusno2 Posted May 16, 2011 Report Share Posted May 16, 2011 No offense man but if ya can't figure out how to route a cable ya prolly shouldn't own a datsun please save someone else the trouble when ya pawn the car off on some other poor soul Quote Link to comment
OMGNOWAI! Posted May 16, 2011 Author Report Share Posted May 16, 2011 No offense man but if ya can't figure out how to route a cable ya prolly shouldn't own a datsun please save someone else the trouble when ya pawn the car off on some other poor soul its not that it's difficult by any means, i was just curious to see how crazy some get. that first response set the bar pretty high haha. routing is simple, but i wanted to see any simple go-to options that work well. i live up the street from a go kart track and they threw me a sleeve wire and fittings for free. now its just a matter of having the time to do it! thanks for the responses everyone, and if you have more pics of ridiculous linkages i know i'll enjoy them at least! cheers! Quote Link to comment
bananahamuck Posted May 16, 2011 Report Share Posted May 16, 2011 Got this carb off of a 521 from a friend , and he was pretty proud of his workmanship actually. Quote Link to comment
Chris#51EPGraham Posted May 17, 2011 Report Share Posted May 17, 2011 I once made a nice cable setup with an '81 Toyota Corolla bellcrank and an '83 Celica cruise control cable. It did require making stop brackets on both ends, and attachment of the pedal end to a stock 510 "monkey link" using a tiny "L" bracket, an M3 screw and some kind of bicycle cable clamp, IIRC. The easy part is that the Corolla bellcrank was a good fit on the 8mm Weber DGV shaft...which also fit the 8mm OEM Hitachi (downdraft) shafts......and so probably also fits Hitachi SU shafts (though I've never tried it on those). Toyota cables are very nice quality though, and never seem to be worn out. Quote Link to comment
