jrdat Posted May 12, 2011 Report Share Posted May 12, 2011 I have a 620kc. I have installed a sr20det and firewall and dash with wireing harness from 180sx half cut from japan. I am working on headlights now.So the only part 620 is the lights themselves. The plugs for the 180 headlights have 5or6 wires. Only one of them has power when lights are on and doesnt change when highbeams are on. Anybody dealt with this before? Quote Link to comment
DanielC Posted May 12, 2011 Report Share Posted May 12, 2011 If it was mine, I would keep all the 620KC electrical, except for the engine. Use the 180 SX wiring for the starting, ignition, and charging system only. Quote Link to comment
MicroMachinery Posted May 12, 2011 Report Share Posted May 12, 2011 ^^ what he said. Quote Link to comment
jrdat Posted May 12, 2011 Author Report Share Posted May 12, 2011 Already installed.I have also ran down all other wires. This is the only thing left. Quote Link to comment
zerow Posted May 12, 2011 Report Share Posted May 12, 2011 Only one of them has power when lights are on and doesnt change when highbeams are on. Anybody dealt with this before? How much power? Less than 12 volts? Probably the Daytime Running Light circuit. Quote Link to comment
banzai510(hainz) Posted May 12, 2011 Report Share Posted May 12, 2011 Isnt the 180sx a one bulb housing????????? Datsuns use mostly a switachble ground. on 510 I know the inner lights will be wired to the Battery(12v) but then gets a ground when switched to High beam.The relay moves to a 2 wire ground then. The outer lamp will be the same thing but use the 2nd element on the bulb Quote Link to comment
jrdat Posted May 13, 2011 Author Report Share Posted May 13, 2011 The 180 headlight plug has 5 wires ground two # 14 one of which has the power when switch is on two # 16 Quote Link to comment
