rt5nine Posted February 21, 2008 Report Share Posted February 21, 2008 Anyone have a extra crankshaft pully laying around or know where I can get one. The crankshaft guide pin rocked up and split the housing on mine. L20b single groove. Link to comment
datzenmike Posted February 22, 2008 Report Share Posted February 22, 2008 Must be the woodruff key you're referring to. Can't see it breaking the pulley shaft unless it was jammed when tightening the 24mm bolt down. L20Bs would have at least 2 vee belt pulleys on them. Replace the timing cover seal when you get your pulley. Link to comment
rt5nine Posted February 22, 2008 Author Report Share Posted February 22, 2008 Yes it was the woodruff key. It is rounded on the shaft side and when the person who built the motor installed the pulley, it rotated up and split the end of the pulley. I had a pretty good oil leak out of the front seal (the split had worn it down). So I pulled off and thats what I found. I had my old pulley from my L18 so I installed that one. I think it did the same thing. The pulley has a slight wooble and I am getting belt dust on my front cover. I tightend to man. specs of 116-ft lb but it looks like it should set back a little further. Is there a difference between the L20B and L18 pulley? I visually thought they looked the same. Link to comment
datzenmike Posted February 22, 2008 Report Share Posted February 22, 2008 As the pulley was installed the key was pushed back and caused the problem. Try installing the pulley first and lining it up and tapping the key in after. Take your time and that should do it. Oh yeah, make sure there isn't any pieces of the old keys jammed in behind where the pulley is going. Use a magnet, but if any pieces fall they'll be safe in the oil pan. Link to comment
banzai510(hainz) Posted February 22, 2008 Report Share Posted February 22, 2008 remeber there are 2 types of pulley One has the timming notch on one side , if timming plate on left or right side on front cover otherwise you wont know the TIME of your motor Link to comment
rt5nine Posted February 22, 2008 Author Report Share Posted February 22, 2008 Yeah I notched with the dremal the old L18 pulley to match the L20B pulley. Thanks for the info. Do you have a extra one? Have cash. Link to comment
banzai510(hainz) Posted February 22, 2008 Report Share Posted February 22, 2008 contack ICEHOUSE on here PM him. He might have one near Everett. Paolo has a few in above Marysville but want like 100$ for one Link to comment
Icehouse Posted February 23, 2008 Report Share Posted February 23, 2008 I bet we do! Bring some cash, we got ton's of parts for sale :D Link to comment
rt5nine Posted February 23, 2008 Author Report Share Posted February 23, 2008 Cool! Where ya at? You can send a PM or call me at (206) 786-3165 Kelly Link to comment
