DISLEXICDIME Posted February 17, 2008 Report Share Posted February 17, 2008 Any one know if a set of 14x7 konig rewind's with a negative 9 off set and 195 60 series tire will fit under stock rolled fender's of a 510 come on tell me what i want to here lol:D Quote Link to comment
fiveNdime Posted February 17, 2008 Report Share Posted February 17, 2008 NOPE hahaha I have no idea Quote Link to comment
kiznook Posted February 17, 2008 Report Share Posted February 17, 2008 can't adam get one to use for testing? Quote Link to comment
Duke Posted February 18, 2008 Report Share Posted February 18, 2008 Under totally stock fenders...no. I wasn't able to fit the 15" zero offset ones without a good deal of fender rolling. But if you used 280zx struts (brings the front wheels in ~1/4 inch) some negative camber in the front, and a shit load of fender rolling they might fit the front. In the rear you would have to roll the fenders to death, and run ALOT of negative camber...and they might fit, but it would be tight (thats what she said). Quote Link to comment
datsunfreak Posted February 18, 2008 Report Share Posted February 18, 2008 With 185s insteads of 195s, you can get away with doing the same tricks as using the 15" Rewinds. Front: 280ZX struts and camber plates Rear: Lots of negative camber (achieved with lots of lowering) and rolled fender lips Bear in mind, this really only works well on a 2dr. The 4drs have different rear inner fenders. Quote Link to comment
datsunfreak Posted February 18, 2008 Report Share Posted February 18, 2008 And if you went with the 15x7 zero offset Rewinds it's easier to fit a bit more rubber (195s). Quote Link to comment
DISLEXICDIME Posted February 18, 2008 Author Report Share Posted February 18, 2008 well my car has 280 zx struts with t3 coil overs camber plates and adjustable tc rod's and the back is camberd out like crazy so i wonder if it will work i am allready running 195 60 14's on some wheels with zero offset Quote Link to comment
datsunfreak Posted February 18, 2008 Report Share Posted February 18, 2008 well my car has 280 zx struts with t3 coil overs camber plates and adjustable tc rod's and the back is camberd out like crazy so i wonder if it will work i am allready running 195 60 14's on some wheels with zero offset You 100% sure? Those rears sure don't look like zero offset. But if they are, I'd definitely give it a shot. I still say 185s would be better, but someone has to be the first one to do everything. :D Pretty sure I was the first to run the 15x7 zero offset Rewinds on a stock fendered car, and still haven't seen many try it... Quote Link to comment
DISLEXICDIME Posted February 18, 2008 Author Report Share Posted February 18, 2008 yah that is the wrong pic i have the match's to the wheels on the front on the back now Quote Link to comment
Duke Posted February 19, 2008 Report Share Posted February 19, 2008 Pretty sure I was the first to run the 15x7 zero offset Rewinds on a stock fendered car, and still haven't seen many try it... You beat me to it by like a week...:mad:...when you posted the pictures on the 510realm I had just received the tires. But I did put 205's on insead of those skinny ass 195's...:fu: Quote Link to comment
datsunfreak Posted February 19, 2008 Report Share Posted February 19, 2008 How much did you have to pull the rear fenders to fit them? My "skinny ass" 195s were within 3mm of the fender. You couldn't get a finger between the tire and fender lip in the rear. Quote Link to comment
Duke Posted February 19, 2008 Report Share Posted February 19, 2008 I had to "persuade" the inner fender quite a bit to get them to fit. They were defineatly very close. I eventually cut the inner fender out and did a sort of mini-tub. Then I ended up hand flaring the fenders a little to. I didn't want to have to run super JDM mega demon camber just to have the wheels. I can now run ~2 degrees of camber...but I still can't fit my finger between the lip and the tire. Quote Link to comment
