jon521 Posted March 17, 2011 Report Share Posted March 17, 2011 with my recent purchase of 71 521, the carb needs to be rebuilt. I was just wondering if there is anything i should know about the stock carbs, if they are worth rebuilding or if they are just no good? I do have a holley/weber 32/36 that needs to be rebuilt and rejetted that i was going to put on once i had some more money. its going to be cheaper to rebuild the my stock one, but i dont want to spend the money if its going to go bad again. so any advice helps! Quote Link to comment
dat77sun Posted March 17, 2011 Report Share Posted March 17, 2011 i wouldnt rebuild the stock carb, there junk, and with the weber there cheaper and give you more power and better throttle response Quote Link to comment
jon521 Posted March 17, 2011 Author Report Share Posted March 17, 2011 Oh ya? So even if I rebuild it, its still no good? Quote Link to comment
DanielC Posted March 17, 2011 Report Share Posted March 17, 2011 The stock carb is not junk. They are really complicated, so it is hard to rebuild them right. A major issue with a stock carb. is its age. If the throttle shaft is worn out, you probably will be better off with a new carb. Quote Link to comment
jon521 Posted March 17, 2011 Author Report Share Posted March 17, 2011 Alright thanks for the advice I appreciate it Quote Link to comment
banzai510(hainz) Posted March 17, 2011 Report Share Posted March 17, 2011 olddatsuns.com the tech section. get a Weber DGV 32/36 5A(manual choke) then get a electric ignition and 80% of your worrys will be gone.!!!!!!!!! Quote Link to comment
Barber Phil Posted March 19, 2011 Report Share Posted March 19, 2011 The weber will be cheaper to rebuild. and Easier. Quote Link to comment
