Topher88 Posted March 7, 2011 Report Share Posted March 7, 2011 I am thinking of getting a 510 with a L20b in it and one of the problems that the guy said was that he bought a three row aluminum radiator on a 10inch fan but he said that the radiator is to be and the fan is to small so when you are not on the road it gets to what he said was 220 until you get moving again where it droops down to the 180's. should that be something that that i need to be extremely worried about? Quote Link to comment
datzenmike Posted March 7, 2011 Report Share Posted March 7, 2011 Datsun gauges don't read in numbers so does it have some aftermarket gauge??? If not then this is meaningless. If it does have an after market gauge and sender and the numbers can be trusted then no, this isn't the best. Get a larger fan or make sure the one on there is turning the right way to pull or push air from outside the grill to in by the engine. Quote Link to comment
Bullet_theory Posted March 7, 2011 Report Share Posted March 7, 2011 agreed with mike.... plus a back flush kit, never hurts to bring those #'s down ;) Quote Link to comment
Topher88 Posted March 7, 2011 Author Report Share Posted March 7, 2011 ok thanks guys :-) Quote Link to comment
Bullet_theory Posted March 8, 2011 Report Share Posted March 8, 2011 wait wait wait, after thought.... did he say that was water temp, or oil temp, cuz that would be different story Quote Link to comment
DISLEXICDIME Posted March 10, 2011 Report Share Posted March 10, 2011 Get a fan shroud and block of the out side edges of the rad so that the air has to go through the rad Quote Link to comment
DISLEXICDIME Posted March 10, 2011 Report Share Posted March 10, 2011 O and how is the temp probe fo the fan mounted and where is it mounted Quote Link to comment
Topher88 Posted March 10, 2011 Author Report Share Posted March 10, 2011 not sure picking up the car tomorrow. ill look. a shroud would not fit there is barley any room between the L20 and the rad Quote Link to comment
hang_510 Posted March 10, 2011 Report Share Posted March 10, 2011 a 3 core should keep it @ 180* w/o any issues. on my LZ22 i have a stock 4 blade plastic fan and a 190* thermostat. runs around 175* (external thermo verified) the rad may be clogged... Quote Link to comment
banzai510(hainz) Posted March 10, 2011 Report Share Posted March 10, 2011 a 3 core should keep it @ 180* w/o any issues. Exactly!!!!!!!!! I would be concerened Quote Link to comment
datzenmike Posted March 10, 2011 Report Share Posted March 10, 2011 I am thinking of getting a 510 with a L20b in it and one of the problems that the guy said was that he bought a three row aluminum radiator on a 10inch fan but he said that the radiator is to be and the fan is to small so when you are not on the road it gets to what he said was 220 until you get moving again where it droops down to the 180's. should that be something that that i need to be extremely worried about? He gets the car today and this info is second hand at best. Previous owner said....... Quote Link to comment
Topher88 Posted March 13, 2011 Author Report Share Posted March 13, 2011 Found out the problem was that the fan was wired the wrong way so i simply switched the wires around and now it gose to about 190 maybe then drops to around 180 :-) yay for installing fans the wrong way! i didnt want to take the whole radiator out so it was fun trying to maneuver my big ass hands in a small ass place but its all fixed and she is running strong. actually makes me think the engine might have work done to it. it honestly sounds like it may have a milled cam but thats purely the way it sound but what the hell do i know. Any way i can find out without tarring apart the engine? Quote Link to comment
datzenmike Posted March 13, 2011 Report Share Posted March 13, 2011 Get a larger fan or make sure the one on there is turning the right way to pull or push air from outside the grill to in by the engine. Well there ya go. Cheaper than buying a new rad right? Quote Link to comment
Topher88 Posted March 13, 2011 Author Report Share Posted March 13, 2011 yes it is :-) car has some new oil temp, voltage and fuel pressure gauges so im glad to have that stuff to monitor. Quote Link to comment
