Minimum head thickness?
inline4
  • Replies 7
Cut as much as you like, but....
The compression will go way up
The timing chain will become slack. This will advance the can timing if not adjusted... or if it even can be adjusted.
Factory head thickness from the valve cover to the block mating surface is 4.248" , anything less is what has been shaved off.
its been shaved, its just a matter of what precautions need to be taken if I'm putting a head, condition unknown onto a block. okay, so if shaved = higher compression but what do I need to watch out for/run with it?
I'm used to stock stuff.
https://lh5.googleusercontent.com/_iyhkKE_FBV4/TWhjRlUKDHI/AAAAAAAAAaY/BVD_8kcOHVc/s640/IMG_20110225_181706.jpg
Seen worse. It should be well within adjustment range if even needed.
What head and how much?
Here's one that's really shaved...
See the bottom of the letters missing?
its the 219 that was f/s the other day. are the valves supposed to stick out like that? :o
  • 4 weeks later...
