stroker setup
erichwaslike
i know the r motor and h motor are basically the same thing and read online in an old nissan racing parts catalog that the h20 crank is considered a stroker for the r16. does anyone know if it is a drop in replacement or is there any machining that needs to be done to it or the block? would i need shorter rods due to the longer stroke?
  • Replies 4
From 1997 Nissan Motorsports Catalog page 30:
Changing the stroke on the R16 5-main engine [from engine # 4001] from 66.8 mm/3.27" will increase total displacement to 1982 cc's. Requires U20 connecting rods [12100-25500]
You need
12200-E0700 R16 Stroker Crank 1 ea
12100-25500 U20 Connecting Rod 4 ea
and of course
12109-25550 U20 Connecting Rob Bolt NLA
12113-25500 U20 Connecting Rod Nut 8 ea.
Bottom line Yes for metric 5 main bearing block, good luck on the stretch bolts for the connecting rods. Based on U20, not H20 [officially at least] No mention of relieving the piston skirts, so take that for what it's worth.
