laotsu Posted January 28, 2011 Author Report Share Posted January 28, 2011 SAAAAAAY most of thos amperages are way different from what i had in there, are you reading off of the cover and are you sure thats a 71? Quote Link to comment
DanielC Posted January 28, 2011 Report Share Posted January 28, 2011 That is reading off the cover. Some amperages I am not too sure about. for example, the headlights. The high beam only lamps were 37.5 watts each, and the high side of the high/low lamps were 50 watts each, That is 175 watts, total. divide by 12 volts, and you get 14.6 amps. A 20 amp fuse should be fine. Reality is that is still a lot of current to run through a 1/4 spade connector. In the picture above, notice how the boot on the red wire has been hot, and burnt slightly. If this connector has been hot, so has the connector clips that hold the fuse. The element in a glass fuse is only soldered to the end caps. I have seen fuses that look good, but have no connection inside them. Quote Link to comment
laotsu Posted January 28, 2011 Author Report Share Posted January 28, 2011 That is reading off the cover. Some amperages I am not too sure about. for example, the headlights. The high beam only lamps were 37.5 watts each, and the high side of the high/low lamps were 50 watts each, That is 175 watts, total. divide by 12 volts, and you get 14.6 amps. A 20 amp fuse should be fine. Reality is that is still a lot of current to run through a 1/4 spade connector. In the picture above, notice how the boot on the red wire has been hot, and burnt slightly. If this connector has been hot, so has the connector clips that hold the fuse. The element in a glass fuse is only soldered to the end caps. I have seen fuses that look good, but have no connection inside them. Quote Link to comment
laotsu Posted January 28, 2011 Author Report Share Posted January 28, 2011 Okay I'll take a look in the morning Thanks guys. Quote Link to comment
