Shaquanda
quincy
Woah I started at the top pictures and was like, "Nice, I'd rock it." Then I scrolled down and it was like "BA_BAM!!" pure sexy man. One of the nicest 610 goons I have seen. COngrats!
(But I am also in love with that Toyota Corona in the background of the other pics!)
thanks, the corona is my buddys :)
  • Replies 38
he got coilovers from techno toy tuning for the front and 4 inch blocks in the rear and its still that high, what to do?
Whoa! He has all of that and is still that high? De-arc the rear springs or flip them over...wow...I never thought I would be saying that after some 4 inch blocks were installed. As for the front...maybe have the struts come out and cut the strut tubes shorter, and run a shorter strut insert...IIRC an AE86 or VW Golf...
...is there a thread on ratsun i can figure out how to flip the leafspring correctly?
That I am not sure about - The concept should be the same for the 620s, or 510 wagon.
The 610 sedans and sport coupes are IRS, so we get springs or cut springs...
Hello zero im running kyb mr2 short struts my fronts are done correct still have 3" of a drop in the front, is there a thread on ratsun i can figure out how to flip the leafspring correctly?
Quincy, you can check my build thread but I modified my front leaf hangers, removed a leaf, had the rest de-arched 1.5" at a spring shop and I have 3" blocks. I augment the travel with air shocks. Not quite sure if the 610 rear is the same but it probably is very similar. I don't think I would flip the leaves but removing a few and adding airshocks to bring back the spring rate worked for me.
Izzo, you're right, you don't want to go crazy with leaf removal. Now that I think about it, I think I just removed the overload. Its been a while and I can't remember how many leafs are in a stock pack. I think that's why I chose to de-arch rather than remove so I would not get axle wrap.
