Jayden71 Posted January 22, 2011 Report Share Posted January 22, 2011 So my L16 has a stock carb on it. When my father in law had the truck the original carb took a crap and instead of buying a weber he just had me buy another new stock carb through the parts house. I told him for the same money he could get a weber with better performance and mpg. He said no, he just wanted it all original. OK fine, his money. So the carb has bout 7500 miles on it, no probs runs great for stock. Starts right up in -20 degree weather. Here lately after it warms up it has been running rough with no choke. If I pull choke cable out just a smidge it smooths out and runs like a raped ape. I mean the choke knob is only out a half inch or less. It idles fine with no choke, under a load is when it coughs and sputters and runs like crap! Any ideas?? I ran it to Idaho like this, choke slightly out. It does not seem to effect mpg or power. l Quote Link to comment
Wide14u Posted January 23, 2011 Report Share Posted January 23, 2011 go get a weber lol :D Quote Link to comment
Sealik Posted January 23, 2011 Report Share Posted January 23, 2011 Vacuum leak....? Quote Link to comment
Jayden71 Posted January 23, 2011 Author Report Share Posted January 23, 2011 go get a weber lol :D Standard Ratsun answer <_< Vacuum leak....? Could be, but from where. No vacuum lines hookrd to it, cept vacuum advace :blink: Quote Link to comment
Wide14u Posted January 23, 2011 Report Share Posted January 23, 2011 take a can of carb cleaner take little shots at the base shoot the vacuum hose you should be able to hear the deference Quote Link to comment
Farmer Joe Posted January 27, 2011 Report Share Posted January 27, 2011 well if you have to get it running by chokin it it, that means that theres something in one of the jets... when you choke its en-richening it at the low speed and it gets the gas i usually should... i would suggested cleaning the jets out... maybe just a whole carb cleaning... and new fuel filters.. i have 2 on my truck.. one by the tank and one by the carb... it helps.. hope you get it figured out.. Quote Link to comment
datzenmike Posted January 27, 2011 Report Share Posted January 27, 2011 Carb icing. Does it have the warm air pipe from the exhaust manifold to the air filter??? Quote Link to comment
