ariascarlos1990 Posted January 12, 2011 Report Share Posted January 12, 2011 Just wondering what different types of front suspension, brake, and wheel combinations people are running on there 510's. Quote Link to comment
510kevin Posted January 12, 2011 Report Share Posted January 12, 2011 im running zx struts with factory brakes, t3 coilovers, t3 camber plates, all new bushings, and tierods. with 15x7 0 offset konig rewinds Quote Link to comment
DISLEXICDIME Posted January 12, 2011 Report Share Posted January 12, 2011 I am running zx struts and brakes some coil overs (I don't know who makes them) 6k springs stock insert 16x9 -13. Wheels Offsentric camber bushings in the controll arms. I really liked my 4 door set up Zx struts and calipers with t3 tc rods t3 225# coil overs with t3 camber plates agx 4 way adjustable struts from a mr2 (had to shorten the strut tube 80mm. And r4s pads Quote Link to comment
five10roller Posted January 12, 2011 Report Share Posted January 12, 2011 sustec pro coilovers 72 510 spindles 72 bmw 320i dual piston calipers they cut the old caliper brackets tig welded new brackets not my preference bought the car this way and is not too bad if i might add and is for sale lol Quote Link to comment
Just Joel Posted January 12, 2011 Report Share Posted January 12, 2011 280zx struts, Takico illumina adjustable inserts, Ermish #225 coilovers, Ermish caster/camber plates... Stock 280zx calipers/rotors/pads... ZX turbo snowflakes 15x6. Later Joel Quote Link to comment
dennis Posted January 12, 2011 Report Share Posted January 12, 2011 I am running 280ZX struts, T3 coil overs, 200lbs springs, Tokico Illuminas, T3 camber plates, stock 280ZX brakes (for now), and Rota RB 15x7 4et. Quote Link to comment
jun Posted January 12, 2011 Report Share Posted January 12, 2011 My wagon has ZX struts/brakes, GC coilovers, KYB GR2 inserts, Tein camber plates, T3 tension rods, poly LCA bushings. I also replaced the tierods, bj's, idler arm, center link, and had delrin idler bushings made by a friend. Also run a 1" swaybar and Earl's stainless lines. recently I replaced the ZX studs with extended ARP studs Front wheels, 14x7.5j -5 SSR MK2 Quote Link to comment
PurePontiacKid Posted January 12, 2011 Report Share Posted January 12, 2011 this thread has entirely too few oics Quote Link to comment
bredatto510 Posted January 18, 2011 Report Share Posted January 18, 2011 Im running 280zx struts gc coilovers with kyb agx inserts wilwood brake kit ss lines, 1 inch sway bar with energy bushings and 14X6 enkei gotti's 0 offset Quote Link to comment
ariascarlos1990 Posted August 9, 2011 Author Report Share Posted August 9, 2011 This thread needs a bump. and its always a plus if you post a pic of your setup. :) Quote Link to comment
