JustinB Posted December 22, 2010 Report Share Posted December 22, 2010 I put in a new engine with a new carburetor and the old air cleaner housing I had from the other engine doesn't really fit very well, and looks ugly as hell now that the engine is so nice looking. I wanted to get a new air cleaner housing but it seems like they all have 5-1/4 (ish) holes for 4bbl carbs. The smallest adapter I can find goes down to 2-5/8 but my carb opening is more like 2-1/4. Anyone know where I can find an adapter? Would help if it had about half an inch or so of rise also because the old housing is really tight against the carb and kinda pushing down on some stuff. Seems to work but I'd rather have a little clearance. Thanks. Quote Link to comment
SRSANDS Posted December 22, 2010 Report Share Posted December 22, 2010 What kind of Carb? Stock Quote Link to comment
JustinB Posted December 22, 2010 Author Report Share Posted December 22, 2010 I think it would be the stock carburetor for a 1979-81 or so A14. Whole thing's kinda pieced together from a few different years. I got it from guaranteed carburetors down in florida. Looks the same as the old carb off my a14 but I don't know what year that engine was for sure. it was, like I said, somewhere around 79-81. Quote Link to comment
JustinB Posted December 22, 2010 Author Report Share Posted December 22, 2010 Here are some pictures. Quote Link to comment
JustinB Posted December 22, 2010 Author Report Share Posted December 22, 2010 You see, it's big, ugly, dirty, doesn't match, and actually doesn't fit right anyway. pushes down on a couple of the carburetor components and there's a gap around the carb throat. Not much, but maybe 1/16" or so. Quote Link to comment
bonvo Posted December 27, 2010 Report Share Posted December 27, 2010 get 2 filer asemblies and take one of the top lids and cut a hole in the center of it that is the size you need then stick it on the carb put one of the filters on and the remaining lid on top the tighten it down with a wing nut if it leaks at the base make a gasket out of an O- ring you can get at a hardware store Quote Link to comment
benzo Posted December 27, 2010 Report Share Posted December 27, 2010 Have you tried to check a K+N catalog to see dimensions of other filters they may have to work on a carburetor? also look at companies like pierce manifold for adapters but I bet K+N will be closer to finding something Quote Link to comment
datsunrides Posted December 28, 2010 Report Share Posted December 28, 2010 Try and find one from an earlier A12/12/14 engine. Pre 75' would be the cleanest. Should bolt up no problem. Mark Quote Link to comment
JustinB Posted December 29, 2010 Author Report Share Posted December 29, 2010 I ended up cutting an adapter ring out of sheet steel, then using an adapter plate for a 2 5/8" and some vaccuum line to make a good seal and reduce the size and then threw a 10" edelbrok filter housing on top of that. Looks sweet. Can't close the hood on it though. @#$%! Gonna have to see what I can do to shrink it all down about 1/4 inch. Of course i could cut the hood and put a cowl on it, which might look cool if I did it right but knowing me, I'd screw it up, so I don't think I'll go that route. Quote Link to comment
villegs Posted December 30, 2010 Report Share Posted December 30, 2010 take the filter itself to a parts store and say i want this, but shorter. Not autozone or pepboys but a good place like napa, bumper to bumper, some O'reilly's have good guys too. Quote Link to comment
Wide14u Posted December 30, 2010 Report Share Posted December 30, 2010 look at a vw shop the old solix carbs look like yours Quote Link to comment
Spades Posted December 31, 2010 Report Share Posted December 31, 2010 do you need an airbox with the vacuum fittings and breather? if not, most places like baxters and autozone can order various sizes of air cleaners from catalogs...I am sure you could find something with the same opening as that carb has, they make many different sizes for british and german cars, and also some motorcycles and lots of custom sizes for various types of air compressors. if you need the air box you have there, you could find someone who can weld, and cut out a hole in a thin steel plate the right size for your carburetor, then cut a hole in that air filter housing you have pictured, and then weld the plate in to your air box shown. use weatherstrip or an o-ring as a gasket for the top of the carb, and you will then have that filter sitting in the right location and be able to close your hood. Quote Link to comment
