kezark31 Posted November 18, 2010 Report Share Posted November 18, 2010 so i heard you can bolt the KA head on the the z block and pick up close to 40 hp depending on the condition of the motor. looking at both head gaskets i belive this is possible. both motors are single row chain driven, the z24 has 106 links at 3/8 pitch while the ka has 102 links @ 3/8 pitch aswell, why is there no builds like this or anything in the jason grey page of this hybrid? Quote Link to comment
philcas1987 Posted November 18, 2010 Report Share Posted November 18, 2010 Aussie forums have this sorta thing covered Quote Link to comment
datsunaholic Posted November 18, 2010 Report Share Posted November 18, 2010 You can pick up some HP vs the stock Z24, but the Z24 block itself is weaker than the KA. It's easier to use the KA block with the KA head and modify the mounts accordingly than do the mods to the Z block/KA head and timing covers. You aren't gaining anything over the stock KA. Quote Link to comment
jesusno2 Posted November 18, 2010 Report Share Posted November 18, 2010 Well if ya look closer you"ll notice the napz and the ka heads are a touch different their a big hole in ka head which is a oil drain back on the napz block that big hole is a coolant passage. Also, The Normal coolant passeges are a different shape. Dunno if that makes much of a difference???? I have a napz block, and a 12v ka head, and have contemplated doing this but in the end it would cost more prolly than to just buy a 12v ka engine, and I would have fuel injection! Quote Link to comment
kezark31 Posted November 30, 2010 Author Report Share Posted November 30, 2010 dug through ozdat could not find anything on this conversion. i got my z24 head torn off. i may just go L series head. the z24 head is cracked between the valves on number 3. i have an fresh surfaced u67 head, i also have a w58 head, wich head would be better to use? Quote Link to comment
Guest kamakazi620 Posted November 30, 2010 Report Share Posted November 30, 2010 dug through ozdat could not find anything on this conversion. i got my z24 head torn off. i may just go L series head. the z24 head is cracked between the valves on number 3. i have an fresh surfaced u67 head, i also have a w58 head, wich head would be better to use? Either one as long as its open chamber Quote Link to comment
datzenmike Posted November 30, 2010 Report Share Posted November 30, 2010 Either one as long as its open chamber Both will give a 9.47 compression ratio so you may need a higher octane fuel. You know that you will have to modify the length of both the timing chain and an L20B timing cover. The Z24 is at least 2cm or 3/4" taller than any other L series cover. See Hang_510 on here I think he still has a cover around that was modified. The Z24 head gasket must be used with holes added to match the L20B h/g and with the front removed and an L20B grafted on to fit the new timing cover at the front. A used one is fine as this isn't holding in any compression or water. It only has to seal in fumes and oil spray. Quote Link to comment
kezark31 Posted November 30, 2010 Author Report Share Posted November 30, 2010 yeah i know about the timing chain my buddy al says eperly has some of the mercedes links so i might hit him up. as for the timing cover i thinl i will just have some ears welded to my z24 cover. can a LZ24 handle any boost instock form with 9 plus compression ratio? im sure super will be a must as welll as a step colder plugs maybe 2 steps. i was thinking 4 to 7 psi intercooled of course. is there any one on this form running an lz24 in a 720? Quote Link to comment
kezark31 Posted November 30, 2010 Author Report Share Posted November 30, 2010 just found this! http://www.farqueue.com.au/manuals/ka24%20head%20conversion/KA24%20L20b%20head%20conversion.htm now i wonder which is more worth while. i have a ka fwd head sitting at work.... if the head can go on an L it can go on a z for sure. most of his conversion parts were z anyways. Quote Link to comment
datzenmike Posted November 30, 2010 Report Share Posted November 30, 2010 Better re-think it. A KA24E head on a Z24 will have a 7.61 compression ratio. A bit low even with turbo. Stock hypereutectec pistons won't survive boost in the 9s without extremely well controled fuel mixtures and lots of detonation control. Quote Link to comment
kezark31 Posted November 30, 2010 Author Report Share Posted November 30, 2010 so what about boosting the lz24 any good? Quote Link to comment
datzenmike Posted December 1, 2010 Report Share Posted December 1, 2010 Boostin' a motor is (or should be) more involved than that. The motor can make 50% or more power. Stress on parts goes up. Heat will build dangerously if the stock system can't get rid of it. Lubrication is even more essential. The next weakest link in the drive train will break, not may break. Quote Link to comment
kezark31 Posted December 1, 2010 Author Report Share Posted December 1, 2010 Boostin' a motor is (or should be) more involved than that. The motor can make 50% or more power. Stress on parts goes up. Heat will build dangerously if the stock system can't get rid of it. Lubrication is even more essential. The next weakest link in the drive train will break, not may break. im aware of whats involved. i just have not scene any boosted lz24's. i just wondering if a stock bottom end can handle 4-7 psi with 9.4 to 1 compresion ratio. fuel and spark control are not an issue i have a stand alone system sitting in the shop. i plan on tossing in some new rings and bearings before i slap it all together. Quote Link to comment
datzenmike Posted December 2, 2010 Report Share Posted December 2, 2010 Have you considered using the Z24 cross flow head. Turbo would have all kinds of room without the intake in the way. Cross flow head is perfect for an inter cooler application. The Z motors use dual plugs and run half the ignition advance than the L series. The compression would be a more manageable 8.5. Z24s are a hemi combustion chamber. Quote Link to comment
kezark31 Posted December 2, 2010 Author Report Share Posted December 2, 2010 thanks for all the help mike, i will just put a z24 head back on, i dropped it off at the mechine shop today will pick up after work. my 521 is happy it gets to keep it u67 head lol. Quote Link to comment
kezark31 Posted December 2, 2010 Author Report Share Posted December 2, 2010 the shop called head is toast! effer on the look out again.... Quote Link to comment
hang_510 Posted December 4, 2010 Report Share Posted December 4, 2010 PM replied Quote Link to comment
