PtheDude Posted October 24, 2010 Report Share Posted October 24, 2010 Allright, the Sano-Orange 75's been on blocks for a month. It's an Auto, purchased running but not driving. Junkyard tranny, the PO told me that the Torque converter was bad cuz it came from the original tranny. Replaced the torque today with a known good. got her running, threw it into gear, and NUTHIN. ARRGGHHH. the vacume lines are connected. there's a wee bit ' o fluid in the tranny, the input shaft is there. Any insight anyone can give, we'd appreciate it! Quote Link to comment
datzenmike Posted October 24, 2010 Report Share Posted October 24, 2010 there's a wee bit ' o fluid in the tranny, What does this mean???? It's essential to have the correct level of ATF in the automatic, do not over fill. Autos change gears and hold themselves in gear by hydraulic pressure. There is a pump in the main body behind the torque converter. Is there enough ATF in it? If you remove one of the cooling lines on the rad and run it does fluid pump out? If so the pump may be alright. This would leave the valve body. The valve body Is full of valves and springs that direct the hydraulic fluid to the correct clutches. When I get home I'll look at my flow charts for the auto. The linkage is working on the side of the tranny? Does anything happen in any of the gear positions at all? mike Quote Link to comment
PtheDude Posted October 24, 2010 Author Report Share Posted October 24, 2010 Mike, we will check the fluid level again, run it and pull the Radiator hose to see if we have a working pump. linkage is good. vacume hoses are connected. the tranny is a JY unit, out of a 280z. I have another one, purchased via RATSUN. any other ideas we can try? Quote Link to comment
PtheDude Posted October 24, 2010 Author Report Share Posted October 24, 2010 oh..we didn't top off the fluid so we dont have to clean up a ton. Quote Link to comment
datzenmike Posted October 24, 2010 Report Share Posted October 24, 2010 When I get home I'll look at my flow charts for the auto. mike Quote Link to comment
nismo dr Posted October 24, 2010 Report Share Posted October 24, 2010 if you are even 2-4 qt lows an auto can slip or not engage at all Quote Link to comment
datsunrides Posted October 24, 2010 Report Share Posted October 24, 2010 Especially if the converter was drained before you installed it. I think the converter, if empty, would hold 4-5 qts. Mark Quote Link to comment
Charlie69 Posted October 25, 2010 Report Share Posted October 25, 2010 When I got my automatic back from the rebuilder he told me to pour 1 quart of transfluid into the torque converter. He also told me to fill the trans with fluid to the level on the dip stick, start the motor and in about 60 seconds check & add fluid as needed. This is because other than assembly fluid the trans is dry as was probably your JY trans. If you did not top off the fluid to the dip stick level, you risk the chance of ruining the pump & torque converter. Worst thing in my book for an automatic transmission is to run them low on fluid. Like Mike said it has to have fluid to work the fluid is not just a lubricant. Quote Link to comment
datzenmike Posted October 25, 2010 Report Share Posted October 25, 2010 The second worst thing next to too little fluid is too much. It will contact the spinning moving parts and because ATF is very detergent it will whip up like a desert topping. This will get sucked into the pump and because air is compressible the hydraulic pressure will drop. Loss of pressure will allow the clutches to slip and wear and get hot burning the fluid. If too full pull a cooling line to the rad and run briefly to drain out the extra. Quote Link to comment
Charlie69 Posted October 25, 2010 Report Share Posted October 25, 2010 oh..we didn't top off the fluid so we dont have to clean up a ton. This is why I posted the low fluid comment. Quote Link to comment
hang_510 Posted October 25, 2010 Report Share Posted October 25, 2010 linkage is good. any other ideas we can try? and adjusted? will it go into gear shifting directly on the tranny? the PO told me that the ... ARRGGHHH. can never trust the PO :sneaky: Quote Link to comment
PtheDude Posted November 9, 2010 Author Report Share Posted November 9, 2010 well tripple topping off the fluid didnt make it work, so out comes the engine, now along with the JY tranny, and we'll put on the one I got via Ratsun. Quote Link to comment
datzenmike Posted November 9, 2010 Report Share Posted November 9, 2010 well tripple topping off the fluid didnt make it work, so out comes the engine, now along with the JY tranny, and we'll put on the one I got via Ratsun. Tripple topping off????????? Did you overfill!!!!! The second worst thing next to too little fluid is too much. It will contact the spinning moving parts and because ATF is very detergent it will whip up like a desert topping. This will get sucked into the pump and because air is compressible the hydraulic pressure will drop. Loss of pressure will allow the clutches to slip and wear and get hot burning the fluid. If too full pull a cooling line to the rad and run briefly to drain out the extra. Quote Link to comment
PtheDude Posted November 9, 2010 Author Report Share Posted November 9, 2010 Tripple topping off????????? Did you overfill!!!!! nope. and we undid the radiator lines to be sure. no juice. maybe the PO overfilled? Quote Link to comment
datzenmike Posted November 10, 2010 Report Share Posted November 10, 2010 With it running and one of the rad lines off...... was there ATF pumping out??? Quote Link to comment
