primo74620 Posted October 16, 2010 Report Share Posted October 16, 2010 I need pictures of a Hitachi Carb. I need all sides. Any links you guys could refer me to will be appreciated. Quote Link to comment
MikeRL411 Posted October 16, 2010 Report Share Posted October 16, 2010 You know which Hitachi card you are talking about. God knows which Hitachi carb you are talking about. God knows you know which Hitachi carb you are talking about. BUT - God knows that we don't know which Hitachi carb you are talking about! Quote Link to comment
primo74620 Posted October 16, 2010 Author Report Share Posted October 16, 2010 You know which Hitachi card you are talking about. God knows which Hitachi carb you are talking about. God knows you know which Hitachi carb you are talking about. BUT - God knows that we don't know which Hitachi carb you are talking about! Funny!!!!!!!! No I don't know what Hitachi carb I am talking about. I need to see the spring that holds the choke valve open. I think the one on my 74' 620 is broken of not properly installed. Quote Link to comment
datzenmike Posted October 16, 2010 Report Share Posted October 16, 2010 The choke valve or plate is held closed by a bi metallic coil inside the electric choke heater. When started, the curent heats the bi metal coil and it expands at a set rate and unwinds, opening the choke plate. The bi metallic coil is inside the choke heater housing: Does this help? It's the return spring for the accelerator pump. . Quote Link to comment
420n620 Posted October 16, 2010 Report Share Posted October 16, 2010 not seeing a choke spring. but it is a pic of one. http://www.olddatsuns.com/data/Hitachi_Carb_DCH_DCP_DRJ340.pdf Quote Link to comment
primo74620 Posted October 16, 2010 Author Report Share Posted October 16, 2010 The choke valve or plate is held closed by a bi metallic coil inside the electric choke heater. When started, the curent heats the bi metal coil and it expands at a set rate and unwinds, opening the choke plate. The bi metallic coil is inside the choke heater housing: . hey datzenmike, I need to see the coil spring that is at the base of the rod the moves the choke plate. I can't tell if it is broken or not. The choke plate is staying closed and I suspect the spring is not pulling on it. Quote Link to comment
datzenmike Posted October 16, 2010 Report Share Posted October 16, 2010 Just remove the three Philips screws around the outside of the heater case and lift off, the coil is inside wrapped around the choke shaft. The choke shaft is horizontal and has the choke plate on it. It might be un hooked inside. . Quote Link to comment
