Cruzn620 Posted January 13, 2008 Report Share Posted January 13, 2008 i need a tail light housing (passenger side) for my 620, doesn't have to be in perfect shape, but must work and have wiring pig tail so i can just plug and play. my right blinker socket has the wire broken inside of itself, and i can't repair it...so let me know what you have and what you want for it. thanks! Link to comment
Guest DatsuNoob Posted January 13, 2008 Report Share Posted January 13, 2008 I can get one, I'll find out a price and get back to you. Link to comment
tdaaj Posted January 13, 2008 Report Share Posted January 13, 2008 put me second in line.. we have some if DatsuNoob can't find any Link to comment
Cruzn620 Posted January 13, 2008 Author Report Share Posted January 13, 2008 you guys are better than the result of walmart and ebay making a baby Link to comment
Guest DatsuNoob Posted January 15, 2008 Report Share Posted January 15, 2008 Hey cruzn, I know I said I could get one, but been real busy at work and cant really find the time to get down there. Maybe Tdaaj can get you one. Sorry dude. Link to comment
banzai510(hainz) Posted January 15, 2008 Report Share Posted January 15, 2008 cruzen620 what you can do is buy another socket at the car parts store(electrical section) for your particlar bulb. 1157/1156 or whatever it is. If 1 contack or 2 contack. cut the old one out and JB weld or your favorite glue in the new socket cup and then splice in the wires , This is how I fix my side marker lights. They are so old that the bulb rots on the socket. I cut the socket off and place in a new one. usually a plstic pc. the JB Weld it in . since it plastic I take the ground side and solder that to the housing(I clean and use MA flux) then wait a few weeks then someone will give you the part FREE!!!!!!Then youll say I went thru the trouble of doing this!!!! Its hard to get datsun people to send stuff so this might be a faster route to get it working before the cops pull you over Link to comment
Cruzn620 Posted January 15, 2008 Author Report Share Posted January 15, 2008 Thanks for the how-to hainz. I didnt know i could just go buy the sockets for the lights like that, since they looked made in, i figured i was going down the "get another" route. since i can't hurt it any worse, i will try your plan. and just like yours, my bulb had rot into the socket. it took a few picks and then a set of needle nose vise grips to get it out. i need to get me a soldering gun so i can make some good grounds with the housing, then i think i'll be set. i have tdaaj working on the part for me right now, and he is really good about shipping...so im still going to try to get the housing, but i'll also see if i can't try your way and at least get it working. i don't have to worry about cops much right now because i still don't have my brakes fixed...so im still not driving it Link to comment
banzai510(hainz) Posted January 15, 2008 Report Share Posted January 15, 2008 here is a website and photos.near bottom Most part stores will have these. or should. Most are all made in China but pick the best one that would work in your application and shape of your part that your putting this in. some are metal, some plastic http://www.taillightking.com/light_bulbs.htm Link to comment
Cruzn620 Posted January 15, 2008 Author Report Share Posted January 15, 2008 hmmm, well at least i know what im looking for now! on the contact thing, im pretty sure it had 2 wires coming out, so i would need to get a double contact socket because of that right? or i guess i could use your theory and solder my ground to the housing, then just run one wire out to the harness and splice in. am i thinking about this correctly? also, this is my turn signal bulb, not a brake or running light....its an 1156. Link to comment
Moops Posted January 20, 2008 Report Share Posted January 20, 2008 Hey cruzn620 I just had a quick ebay peek cuz I was sure a new pair were always on there for pretty cheap, not sure if this link will work for you, item # 260204149127 if it doesn't. Hope this helps. http://cgi.ebay.com/ebaymotors/Datsun-620-pickup-tail-lights-pair-NEW_W0QQcmdZViewItemQQcategoryZ33716QQihZ016QQitemZ260204149127QQrdZ1QQsspagenameZWDVW Link to comment
datzenmike Posted January 20, 2008 Report Share Posted January 20, 2008 Cool amber turn lens too. Link to comment
