globe471 Posted October 6, 2010 Report Share Posted October 6, 2010 my truck is starting to tuck or tugging really bad in the mornings or when its cold until it warms up it never did that before what can be can be causing this problem? and how can i get rid of it? has l20b with webber 32 36 crab Quote Link to comment
DatDoug Posted October 6, 2010 Report Share Posted October 6, 2010 The cause? :unsure: Its getting cold outside :blink: The cure? :unsure: Let it warm up before driving <_< Takes a Datsun 20 min to warm up on cold days. Quote Link to comment
datzenmike Posted October 6, 2010 Report Share Posted October 6, 2010 Tuck, tugging? You mean it jerks when you step on the gas? Like the key is being turned off and on? Hard to let the clutch out and drive away? Got a choke? Does it work? On start up does it have a fast idle? Properly set up you should be able to get in start it click your seat belt and go. My '710 is an L18 automatic. Works perfectly. Quote Link to comment
Pumpkn210 Posted October 6, 2010 Report Share Posted October 6, 2010 In the winter I use a piece of cardboard to cover most of my rad ;) Quote Link to comment
globe471 Posted October 6, 2010 Author Report Share Posted October 6, 2010 Tuck, tugging? You mean it jerks when you step on the gas? Like the key is being turned off and on? Hard to let the clutch out and drive away? Got a choke? Does it work? On start up does it have a fast idle? Properly set up you should be able to get in start it click your seat belt and go. My '710 is an L18 automatic. Works perfectly. has an electric choke but how do i know if it works or not? no it does not have a fast idle its kinda ruff for about 10 min and its a smooths out Quote Link to comment
Skib Posted October 6, 2010 Report Share Posted October 6, 2010 let it warm up for like 15min before you take off in the morning ;) Quote Link to comment
datzenmike Posted October 6, 2010 Report Share Posted October 6, 2010 When cold take air filter off and look at it. Should have the choke butterfly more or less open like this: Pump the gass once and it should close like this: When the choke is set properly it will run richer and also engage the fast idle cam for faster warm ups. Cold engines don't evaporate and mix fuel well with cold air so running rich will help. This is what the choke does. If choke is sticking spray the linkages with carb cleaner or WD-40 and work back and forth to loosen. You may have to hold the throttle open slightly. . Quote Link to comment
globe471 Posted October 16, 2010 Author Report Share Posted October 16, 2010 When cold take air filter off and look at it. Should have the choke butterfly more or less open like this: Pump the gass once and it should close like this: When the choke is set properly it will run richer and also engage the fast idle cam for faster warm ups. Cold engines don't evaporate and mix fuel well with cold air so running rich will help. This is what the choke does. If choke is sticking spray the linkages with carb cleaner or WD-40 and work back and forth to loosen. You may have to hold the throttle open slightly. . yeah its defiantly broken or something the butterfly dose not move just stay open... Quote Link to comment
Cuts metal like mad Posted October 17, 2010 Report Share Posted October 17, 2010 Dont tug it when its cold. You might break it off! Quote Link to comment
datzenmike Posted October 17, 2010 Report Share Posted October 17, 2010 Hold the throttle partly open and see if it is free to move and not seized. Now loosen the three screws on the choke heater and turn (twist) the black housing left to add choke (rich) and right to have less choke (lean) Choke plate should close. Start, warm up, in about 5-8 minutes the choke will slowly open. If everything working. Check that there is 12 volts on the RED wire when running.... has to be running to check this. Without power the choke heater won't warm the choke coil an the choke will not come off fully. AHHHH I see you have a 521, sorry, it may use a manual choke. There should be a knob on the dash that you pull out to set the choke on. Quote Link to comment
