QA1 Coilovers New price $175
These shocks are sold by a company called Aldan American, but are manufactured by QA1. The QA1 part # is DR5855P, the aldan part number is PAS 658.
I would like to use these myself, however I wont be able to get to that any time soon. They came off of a show car with less than 1000 total miles on the entire car!
Of course, as you probably already know, QA1s are fully rebuildable.
Check here to see that what I say is true.
http://www.hotrodsus...tore/aldan.html
Original price is $180 each NOT including springs!
They are missing 1 and a half bushings, which are cheap. They measure 16 inches eye to eye, with a 12 inch 300lb/in spring.
I would prefer a local sale, but I am also willing to ship these at your expense. Thanks for looking.
  • Replies 20
QA1 has a kit that converts the eye to a bolt. If the shock compression is between 12.225" and 13.5" and has 5 to 6" of stroke then it should work.
Depends on the purpose of putting them on. In order to run these in the rear of a 510, the shock tower will need to be reinforced. While reinforcing, a guy could set his ride height based on how tall or short he made his shock towers.
True, I was basing my information on a simple bolt in application. Many people run similar coil-over setups on the rears with no structural issues with the shock towers. I of course would strengthen that area.
Never heard of a problem with the towers, but people have broken the lower shock stud mount.
  • 2 weeks later...
  • 3 weeks later...
Very interested ..where r u located im at 11772 what would the shipping there be ?? whats the rate of the springs..?? thanks ..Sorry just re read it they r 300lbs...is this too much/not enough or just right for a track 510????
