Lude944 Posted September 30, 2010 Report Share Posted September 30, 2010 So i finally got a round to replacing the brakes finished the front no problem moved to the rears and i cant make everything fit back together [by the way this is my first ever drum brake job always had all disc brakes] anyway i can get everything on except i cant make the extension link fit with the toggle lever for the e-brake. any tips or tricks that a first timer wouldn't be aware of otherwise? heres a pic of what she looks like Quote Link to comment
Lude944 Posted October 3, 2010 Author Report Share Posted October 3, 2010 Wow 37 views and not one suggestion, come on i know there' some one out there with something. I will try an get a shot of the brakes later today. Quote Link to comment
Jayden71 Posted October 3, 2010 Report Share Posted October 3, 2010 44 views now Quote Link to comment
SRSANDS Posted October 21, 2010 Report Share Posted October 21, 2010 Crawl under the truck and loosen the turnbuckle up to give the cable more slack Quote Link to comment
Charlie69 Posted October 22, 2010 Report Share Posted October 22, 2010 Be sure the adjusters are turn all the way in to shorten them & also make sure that you e brake adjustment is all the way loose. Post some pictures of the problem you are having & of the assembled brakes may something is not put together quite right. Quote Link to comment
wayno Posted October 23, 2010 Report Share Posted October 23, 2010 Hey Lude944, are you trying to put the cable on the e-brake arm with the rear brake shoe in position? wayno Quote Link to comment
Charlie69 Posted October 25, 2010 Report Share Posted October 25, 2010 Hey Lude944, are you trying to put the cable on the e-brake arm with the rear brake shoe in position? wayno Good question Wayno. You put the e-brake cable on before putting the shoe on the backing plate. Quote Link to comment
