JustinB Posted September 16, 2010 Report Share Posted September 16, 2010 Having trouble with my 210 wagon. It's a 1979 wagon with an A14 engine that's seen better days. Have a fresh new engine to put in but I am waiting on the cash for a couple parts to finish it up. ANYWAY... Problem is it won't idle. Runs same as always when driving, although I can hear this vibration/buzzing sound I don't recognize, but when I stop, it dies. tried upping the idle but it didn't work unless i raised it WAY too high. Like up over 2k. Then it'll stay running but it sounds horrid. Anyone having ideas, hit me up. Thanks. Quote Link to comment
metalmonkey47 Posted September 16, 2010 Report Share Posted September 16, 2010 Can you get a video? Check your vac lines for leaks. Quote Link to comment
datzenmike Posted September 16, 2010 Report Share Posted September 16, 2010 Idle cut solenoid maybe? Have someone turn the key on/off/on/off (don't start) and listen near the carb. You should hear a clicking sound. If no click the idle circuit will not get gas. Quote Link to comment
paradoxx Posted September 16, 2010 Report Share Posted September 16, 2010 Idle cut solenoid maybe? Have someone turn the key on/off/on/off (don't start) and listen near the carb. You should hear a clicking sound. If no click the idle circuit will not get gas. I double that. Quote Link to comment
JustinB Posted September 17, 2010 Author Report Share Posted September 17, 2010 I'll try that in the morning. How much would an idle solenoid cost, and what does it look like? Thanks for the quick help. Any money I don't give a shop is more I can use to finish the new A15. Thanks again. Quote Link to comment
Dguy210 Posted September 17, 2010 Report Share Posted September 17, 2010 I'll try that in the morning. How much would an idle solenoid cost, and what does it look like? Thanks for the quick help. Any money I don't give a shop is more I can use to finish the new A15. Thanks again. http://datsun1200.co..._solenoid_valve Quote Link to comment
JustinB Posted September 17, 2010 Author Report Share Posted September 17, 2010 Alright. Looks like the guy who owned it before just twisted the wires together, so I cut them clean and touched them together with the ignition on. There was a very very slight clicking so I put spade terminals on and wrapped them up good with electrical tape. Still wouldn't idle regular, so I just turned it up until it would stay and figure I'll live with it for now. I have a few other projects going right now, all of them on hold due to a cashflow issue. Trying to sell my boat to raise funds and then I should be able to get everything done. Quote Link to comment
datzenmike Posted September 17, 2010 Report Share Posted September 17, 2010 Things that will affect your idle: 1/ Check your hot valve lash. 2/ Set ignition timing Now set carb mixture and idle speed. Set idle so engine will run. Turn idle mixture screw in or out until idle falters then quickly turn the other direction until it does the same. Select a point roughly in between where idle is fastest and smoothest and re-adjust the idle speed down. Turn idle mixture in and out to find the best idle position, adjust idle speed down... repeat until idle quality can't be improved. Be sure to do 1/ and 2/ above first. Quote Link to comment
