LeDevil Posted January 4, 2008 Report Share Posted January 4, 2008 Well it's almost time for tires but before that I need to know what to do about my 16" Chevy rims. Couple people told me to run spacers, 1 person told me 1/2" another told me 1/4". So you guys running Chevy/Caddy rims let me know what your using. They're going on my 75' 620, These are what the rims look like if it helps as always thanks in advance Quote Link to comment
Bleach Posted January 4, 2008 Report Share Posted January 4, 2008 you bore them out from the back side. 1/2" deep like I did on my Titan wheels. 1/2 inch rabitting router bit is what you need. Your router will have either a 1/4 or 1/2 inch shank on it. Make sure the bit's shank matches that. Most are 1/2 inch. I had a router with a 1/4 inch shank and had to order the bit online. I went down 1/16th of an inch each time. (like the 2nd video shows) Quote Link to comment
]2eDeYe Posted January 4, 2008 Report Share Posted January 4, 2008 ....or 1/4" spacers.... I machined my hubs, that way I can run any wheels I want without spacers :D Quote Link to comment
Jester Posted January 5, 2008 Report Share Posted January 5, 2008 I ordered a pair of 1/4" shims for my Chevy Suburban wheels. I figure I'll try one shim first then try the two together to see if it really NEEDS 1/2". If it does I'll buy a pair of 1/2's and put the 1/4's in the rear. Jester Quote Link to comment
