Want a 5 Spd from 78 or 79 Pick Up!
  • Replies 5
'77 was the first year for the 5 speed in the 620 and 280z. The '77 and '78 truck trannys were identical for gearing but the '79 was a wider ratio. Also the '77-'79 280z car 5 speeds were the same as the '77-'78 truck tranny so they will fit as well.
The '80-'83 280zx non turbo 5 speed will also work but they do have a very high 5th over drive and the L16 may struggle to use it on the highway.
The '77 and '78 truck tranny gears (all forward and reverse) are the same as the '77-'79 z and zx. From '80 on they are closer ratios. The '79 truck used a much lower first because that year standard used a lower 4.11 ratio differential.
I also forgot to mention the '79-'84 810/Maxima also used the same '77-'78 truck 5 speed gears, and why not the Maxima was built on the 280z/zx platform anyway.
