Dattosan Posted August 17, 2010 Report Share Posted August 17, 2010 <a href="http://s1012.photobu...urrent=4545.jpg" target="_blank"><img src="http://i1012.photobu...e%20it/4545.jpg" border="0" alt="Photobucket"></a> <a href="http://s1012.photobu...current=565.jpg" target="_blank"><img src="http://i1012.photobu...ke%20it/565.jpg" border="0" alt="Photobucket"></a> <a href="http://s1012.photobu...rrent=iuiui.jpg" target="_blank"><img src="http://i1012.photobu...%20it/iuiui.jpg" border="0" alt="Photobucket"></a> im starting to think maybe the cooling system if the problem for my overheating? still havent pulled the head out so cant tell if the gasket blew or not im lagging iknow haha i just dont know the whole deal with the camgear and the timing chain check out the pics could anyone point out tthe specs i highlighted it was worse before thats how it looked after i wiped some of it off orange water mark looking stuff on the camgear Quote Link to comment
Skib Posted August 17, 2010 Report Share Posted August 17, 2010 forums use IMG tags to display pictures ;) Quote Link to comment
datzenmike Posted August 17, 2010 Report Share Posted August 17, 2010 That motor looks like it's been at the bottom of the ocean for a few years. It takes a long time to get that bad. If the engine was left in the car it was done so with out the protection of anti-freeze coolant. orange water mark looking stuff on the camgear Maybe it really is a water mark and that block was in a ditch for a couple of years. . Quote Link to comment
Dattosan Posted August 17, 2010 Author Report Share Posted August 17, 2010 <a href="http://s1012.photobu...urrent=4545.jpg" target="_blank"><img src="http://i1012.photobu...e%20it/4545.jpg" border="0" alt="Photobucket"></a> <a href="http://s1012.photobu...current=565.jpg" target="_blank"><img src="http://i1012.photobu...ke%20it/565.jpg" border="0" alt="Photobucket"></a> <a href="http://s1012.photobu...rrent=iuiui.jpg" target="_blank"><img src="http://i1012.photobu...%20it/iuiui.jpg" border="0" alt="Photobucket"></a> im starting to think maybe the cooling system if the problem for my overheating? still havent pulled the head out so cant tell if the gasket blew or not im lagging iknow haha i just dont know the whole deal with the camgear and the timing chain check out the pics could anyone point out tthe specs i highlighted it was worse before thats how it looked after i wiped some of it off orange water mark looking stuff on the camgear Quote Link to comment
Dattosan Posted August 17, 2010 Author Report Share Posted August 17, 2010 forums use IMG tags to display pictures ;) why thanks Quote Link to comment
banzai510(hainz) Posted August 18, 2010 Report Share Posted August 18, 2010 clean off that white speks behine where the water pump sat. and ck the metel very closely, there could be a tiny hole you can barely see. Like I said earlier to you look like termites went threw it. I would ck the tinning cover for the hole first since you said water went in the oil. But i think you said it was cooming out the pipe also. Fuck it! almost better to get another motor what I see so far. l16 are ez to come by. OR watch this NAKED first and after 80 minutes youll know more ans ask better question. http://www.guba.com/watch/3000024223/Hainz-Datsun-L-Series-Engine-01-Timing-Tare-down-and-Rebuild Quote Link to comment
Dattosan Posted August 18, 2010 Author Report Share Posted August 18, 2010 a new motor? i dont wana do that yett.. if iget a new motor it will be a ka24... but this motor runs strong i wana fix it for now Quote Link to comment
datsunaholic Posted August 18, 2010 Report Share Posted August 18, 2010 That engine "runs strong"??? I wouldn't run it. And I've run some serious junk. Cam, water pump, and timing cover alone are lost causes. Thing looks like it has been submerged. I've seen engines that ran total-loss cooling in salt water for decades (boat engines) that look better than that. Quote Link to comment
Dattosan Posted August 18, 2010 Author Report Share Posted August 18, 2010 well yeah i guess minus well invest in a new motor this thing was left behind sitting for years so.. whoknows Quote Link to comment
nismo dr Posted August 18, 2010 Report Share Posted August 18, 2010 That engine "runs strong"??? I wouldn't run it. And I've run some serious junk. Cam, water pump, and timing cover alone are lost causes. Thing looks like it has been submerged. I've seen engines that ran total-loss cooling in salt water for decades (boat engines) that look better than that. I agree with every word of that. I'm amazed it ran at all let alone strong Quote Link to comment
