ricky Posted August 16, 2010 Report Share Posted August 16, 2010 hi i have a 1972 datsun with an l16 and a webber carb cant seem to find the numbers on it to get a rebuild kit for it also. i cant seem to find any spot to hook up vacuum advance Quote Link to comment
jefe de jefes Posted August 16, 2010 Report Share Posted August 16, 2010 Down draft weber? Numbers usually located on the base of the carb. Quote Link to comment
SublimeDatsun610 Posted August 16, 2010 Report Share Posted August 16, 2010 no vacuum advance port means side draft. Quote Link to comment
ricky Posted August 18, 2010 Author Report Share Posted August 18, 2010 im new to the whole 4 cylinder thing im used to 4 barrel Holleys. so i have no idea what kind of webber it is ill post pictures tomorrow. all i know its mounted to a stock l16 Quote Link to comment
RoadRace Posted August 19, 2010 Report Share Posted August 19, 2010 im new to the whole 4 cylinder thing im used to 4 barrel Holleys. so i have no idea what kind of webber it is ill post pictures tomorrow. all i know its mounted to a stock l16 if its bolted to the side of an intake, then its a side draft, if its on top of the intake manifold, its most likely a 32/36 DGV 2 barrel. does it have 2 square looking chokes? then thats it - is it manual choke or electric? there isn't much to rebuild on it. the pump or power valve is 15 - 18 bones, the rest is just washers and a top gasket. i had good service getting the stuff i needed from Pierce Manifolds. as far as vacuum advance, on the datsun its usually ported off the manifold itself, not the carb. but depending on the year of the carb you have there should be at least 1 vacuum port on the bottom part of the carb body, but it's possible there are none. Holley bought the rights to manufacture the DGV/DGAV and put in on EVERY K-car they made until 85 or 86 with some differences (smog complications)to the original Weber. so if you're use to Holley's, then you should be Ok with that one! Quote Link to comment
banzai510(hainz) Posted August 19, 2010 Report Share Posted August 19, 2010 Roadrace you sure about that? on the datsun its usually ported off the manifold itself, not the carb. Its on the carb the vaccum port. Weber DGVs have a port at the base next to the tension screw. Or soembody plugged it up. webers dont really need to be rebuilt. As Roadrace said there is a new diaphrame for accel pump and needle valve for the gas to come it but the rest it just gaskets. My DGV was over 12years old and I never rebuilt it. what makes you believe the carb is bad. if anything get a EI ignition so you can rule out that side first then move to the carb. Thats a nice 510 you have. take care of it not many nice ones left Quote Link to comment
ricky Posted August 19, 2010 Author Report Share Posted August 19, 2010 it needs a new accelerator pump so I figured I'd rebuild the whole carb it bolts to top of manifold. Thanks for the input ill look for spots on maifold to hook up vac advance Quote Link to comment
banzai510(hainz) Posted August 19, 2010 Report Share Posted August 19, 2010 you should NOT hook up to the manifold but the carb port webercarbsdirect has kits or if you only need the accell punp you dont even have to take the carb off. Then youll now if that was the proplem or not.go to olddatsuns.com has alot of infor for new datsun ownser Quote Link to comment
ricky Posted August 19, 2010 Author Report Share Posted August 19, 2010 ok so what do i do about the vacuum advance if there isnt anywhere to put it on carb. because i can not find a little port here are pictures Quote Link to comment
Sealik Posted August 20, 2010 Report Share Posted August 20, 2010 On the last pic.....what is just above the 12mm bolt holding the carb down? That looks like a broken brass fitting....? Same location for my vacuum advance (hook-up) on my 32/36. There are 2 schools of thought on connection. Redline suggests carb vacuum...some have hooked to IM. I'm running mine from the carb......and I don't think my 84 Z24 4x4 could do any better than 30 MPG (highway) and or performance by switching it to IM. :P Quote Link to comment
ricky Posted August 20, 2010 Author Report Share Posted August 20, 2010 Ok that is a stick that some one stuck in there that is actully nothing I pulled it out and no changed I beleave I found where the vacuum port is and it is missing the brass fitting. Good old fashion starting fluid found the spot thanks for all advice Quote Link to comment
Sealik Posted August 20, 2010 Report Share Posted August 20, 2010 Ok that is a stick that some one stuck in there that is actully nothing I pulled it out and no changed I beleave I found where the vacuum port is and it is missing the brass fitting. Good old fashion starting fluid found the spot thanks for all advice Well.....where is it? Left of your stick? Quote Link to comment
ricky Posted August 20, 2010 Author Report Share Posted August 20, 2010 Left of stick the linkage is blockin it from picture Quote Link to comment
ricky Posted August 20, 2010 Author Report Share Posted August 20, 2010 I used a dental mirror to find Quote Link to comment
ricky Posted August 20, 2010 Author Report Share Posted August 20, 2010 After startin fluid pointed me to it Quote Link to comment
Sealik Posted August 20, 2010 Report Share Posted August 20, 2010 Left of stick the linkage is blockin it from picture Figured.....wonder why the stick was jammed in the other? Quote Link to comment
ricky Posted August 20, 2010 Author Report Share Posted August 20, 2010 Think owner before me thought it was vacuum Quote Link to comment
Sealik Posted August 20, 2010 Report Share Posted August 20, 2010 Usually there are 2 fittings in that locale......one for vacuum advance....and the other goes to canister. Which most people plug........other than with a stick :lol: Quote Link to comment
ricky Posted August 20, 2010 Author Report Share Posted August 20, 2010 I pulled stick out and sprayed starting fluid straight in it and no change in idle Quote Link to comment
Sealik Posted August 20, 2010 Report Share Posted August 20, 2010 I pulled stick out and sprayed starting fluid straight in it and no change in idle Gonna assume there is some stick residual left in there..... :D Quote Link to comment
ricky Posted August 20, 2010 Author Report Share Posted August 20, 2010 Its fine I'm going to do a rebuild and get it plated yellow to match car Quote Link to comment
datsunfish Posted August 20, 2010 Report Share Posted August 20, 2010 If you cant find a replacement pipe for the vacuum port im sure a little backyard ingenuity could make something work. Just need something that seats in tight to put the hose on. If nothing comes around or works for you let me know Im sure I have some of them floating around in my box o webers. Quote Link to comment
ricky Posted August 20, 2010 Author Report Share Posted August 20, 2010 Thank you very much for the offer. My friend owns a machine shop and is making one for me. Quote Link to comment
RoadRace Posted August 20, 2010 Report Share Posted August 20, 2010 Roadrace you sure about that? hey Hainz- you mean about Holley using the DGV for K-cars? 100%. its almost un-recognizable, until you get the top off, then its easy to see. thats where i got most of my jets and tubes from when i ran a DGV. not sure how many carbbed kcars there are in the yards anymore, but they all had 'bastard' DGVs on them. Quote Link to comment
