solow720 Posted July 28, 2010 Report Share Posted July 28, 2010 whats up i have a bit of a problem the tail lights on my 86 720 stay on and kill the battery i dont know what the problem is they work fine just wont turn off any help would be great thanks. Quote Link to comment
Phixius Posted July 28, 2010 Report Share Posted July 28, 2010 I had the same problem in my 521. What I did to fix mine was adjust the pedal stop, I just back off the jam nut where the lever rests on a rubber stop and tighten it a tuch (for more pedal travel). see if that helps. Quote Link to comment
kmc63 Posted July 28, 2010 Report Share Posted July 28, 2010 That was my first thought. Did that fix it? Quote Link to comment
datzenmike Posted July 28, 2010 Report Share Posted July 28, 2010 Tail or running lights are one thing then there are the brake lights. Which one is it because adjusting the brake switch won't help the running lights. Quote Link to comment
Phixius Posted July 28, 2010 Report Share Posted July 28, 2010 Tail or running lights are one thing then there are the brake lights. Which one is it because adjusting the brake switch won't help the running lights. Good call. But, if his running lights are on though, then his marker (front/side) lights would be on aswell, right? If its just the rears, I would assume its the brake. But if it is the running lights, I would check the Headlight Switch first, either with a multimeter or with a different switch and go rom there. Quote Link to comment
hang_510 Posted July 28, 2010 Report Share Posted July 28, 2010 If its just the rears, I would assume its the brake. But if it is the running lights, I would check the Headlight Switch first, either with a multimeter or with a different switch and go rom there. tail lights ON and no brake/parking lights could be a short. is it an intermittant or constant problem? Quote Link to comment
banzai510(hainz) Posted July 28, 2010 Report Share Posted July 28, 2010 go the the brake pedal and look what the switch is doing. On my 521 the plate that pushes the the brake light switch broke. thus the switch extends the plunger out thus shortng out the switch leaving the light on. I JB Welded a penny on the brake arm thus puses the switch in when Peadal is exdended SIMPLE FIX or swithc is just bad. ohm it out. plunger out is shorted plubger In its a Open Quote Link to comment
datto510 Posted July 28, 2010 Report Share Posted July 28, 2010 go the the brake pedal and look what the switch is doing. On my 521 the plate that pushes the the brake light switch broke. thus the switch extends the plunger out thus shortng out the switch leaving the light on. I JB Welded a penny on the brake arm thus puses the switch in when Peadal is exdended SIMPLE FIX or swithc is just bad. ohm it out. plunger out is shorted plubger In its a Open Did the same thing. Quote Link to comment
solow720 Posted July 28, 2010 Author Report Share Posted July 28, 2010 thanks all i figured it out all i had to do is back off the brake switch that is at the top of the brake peddle Quote Link to comment
hang_510 Posted July 28, 2010 Report Share Posted July 28, 2010 so it was the brake lights and not the taillights... <_< glad you got it fixed! Quote Link to comment
datzenmike Posted July 29, 2010 Report Share Posted July 29, 2010 so it was the brake lights and not the taillights... <_< :lol: :lol: :lol: :lol: Quote Link to comment
