benson64L Posted July 16, 2010 Report Share Posted July 16, 2010 I just put a Holly electric fuel pump on my truck with out a a pressure regulator and ran it a couple times, could it have blown out one of the gaskets in the carburetor? I was thinking it is the accelerator pump? I would really appreciate the help thnx Quote Link to comment
INDY510 Posted July 16, 2010 Report Share Posted July 16, 2010 What motor? L20B? How much pressure is the elec. pump producing? ........... did you bypass the mechanical fuel pump? Quote Link to comment
banzai510(hainz) Posted July 16, 2010 Report Share Posted July 16, 2010 start car then shut off. the carb should be full in bowl.then cycle the linkage to see if gas is squirting in the barrel of the carb if yes the accelpump works . If not the accl pump is stick IN or bowl is empty or massive hole. You need a pump of about 2.5 -4 pounds thats it. Quote Link to comment
benson64L Posted July 16, 2010 Author Report Share Posted July 16, 2010 Yeah its the L20b. I took the mechanical pump off. The electric pump produces about 7 but i have a regulator on it and have it set at about 3.5. I will check to see if the accer. pump is squirting or not. Quote Link to comment
banzai510(hainz) Posted July 16, 2010 Report Share Posted July 16, 2010 time motor also to ck distributor bolt is loose and running out of time. but to me its accell pump if it was OK before and not work was done on car/truck. if lossing a cylinder ck the spark plug/wire then valve lash spec or ee if lash pad fell off olddatsuns.com Quote Link to comment
datzenmike Posted July 17, 2010 Report Share Posted July 17, 2010 I just put a Holly electric fuel pump on my truck with out a a pressure regulator and ran it a couple times, could it have blown out one of the gaskets in the carburetor? I was thinking it is the accelerator pump? I would really appreciate the help thnx You can't blow out any gaskets in the carb so don't worry about that. Too much fuel pressure could over power the float/needle valve and over fill the bowl but it is vented into the primary. Any overflow will just flood the engine and it will run rich (or not at all) and blow black smoke, plugs will be powdery black and hard to restart when warmed up. If you have a pressure regulator run it as low as possible. Try 2 1/2 - 3 PSI. If pressure is too low motor will cut out under heavy load like climbing a steep hill and act like running out of gas. If so turn pressure up very slightly until this goes away. Quote Link to comment
hang_510 Posted July 20, 2010 Report Share Posted July 20, 2010 fuel filter / lines clogged? Quote Link to comment
