wildmaninid Posted July 3, 2010 Report Share Posted July 3, 2010 Anyone else have this on their datsun?? At first i thought it was part of the factory a/c system, but as I took it out I realized it was wired into the main harness.........it works but isn't accurate if indeed it is an hour meter.......Never seen anything like it before. Any insight? It is past 3 in the morning an i cant effin sleep... Bill Quote Link to comment
Braden Posted July 3, 2010 Report Share Posted July 3, 2010 its an egr timer, tells you when to clean the cabron out of all that junk, when it gets so high in number it makes the dash light come on, i took mine off, open up the little black cylinder in , unplug it and chuck it. cleans things up on that side of the engine bay thats for sure Quote Link to comment
deadmonkey Posted July 3, 2010 Report Share Posted July 3, 2010 I was wondering what that little bugger was for. I chucked mine as well (in a box of course). Quote Link to comment
datzenmike Posted July 3, 2010 Report Share Posted July 3, 2010 its an egr timer, AKA: detector drive counter. Mid 70s motors had them later ones didn't. An EGR valve with carbon build up can hold the valve open slightly in effect causing a vacuum leak that will cause a poor idle quality. Quote Link to comment
wildmaninid Posted July 3, 2010 Author Report Share Posted July 3, 2010 Well now that makes sense. I thought perhaps it was something that kept track of time on the a/c compressor, since the old compressors you had to change the oil in regularly. I will be pitching it out I believe, but into a box to keep just in case it might be worth something someday! Quote Link to comment
datzenmike Posted July 3, 2010 Report Share Posted July 3, 2010 Maybe they thought carbon would be a problem and later dropped it because it wasn't? '75- '77s had it but not after '78. The 'pre '78s had the exhaust manifold bolted to the bottom of the intake and used exhaust heat to help warm and vaporize the fuel. '78s and on used the hot water piped through the intake runners to do the same. Who knows. Quote Link to comment
wildmaninid Posted July 4, 2010 Author Report Share Posted July 4, 2010 Yea not sure of the reasoning/technology behond some of those features. Well thanks for helping me solve this small mystery. Bill Quote Link to comment
Willdatsun Posted September 5, 2012 Report Share Posted September 5, 2012 just found one of these on my truck, wondered what the hell it was, thankyou! Quote Link to comment
