ztommyx510 Posted June 11, 2010 Author Report Share Posted June 11, 2010 wow. makes more sense now. i'll give it a try. thanks! Quote Link to comment
ztommyx510 Posted June 13, 2010 Author Report Share Posted June 13, 2010 damn, i'm still confused on it all... i think i have too many wires and don't know what to do with them. again, where does these wires go again? the GREEN relay is for the fuel pump... so i assume the first set of relay (on the diagram) is taken care of? this: thick red wires have an inline 15A fuse, yellow wire have a 30A fuse now i have these wires from the 510 harness and do not know where these go this looks like power wires of some sort? closeup on all these wires and then! there's these wires... these are near the wiper motor i assume these goes inside the hole into the steering column? but there is nothing in the steering column to connect to? here's the pic close up anyone know what these wires are for? any help would be appreciated. Quote Link to comment
sssr20det510 Posted June 15, 2010 Report Share Posted June 15, 2010 the only wire you need out of your wirering for the 510 harness part is factory alt and voltage regualtor i belive it is the white with red stripe that went to the volt reg. you run that to the alt. The other 510 part that needs to go to the engine bay should be starter signal wire(black with yellow stripe) and headlight wiring. as far as the wiper motor wires i belive the hook up inside the car on the passanger side under the dash And you should have the coil signal wire already hooked up Quote Link to comment
ztommyx510 Posted June 15, 2010 Author Report Share Posted June 15, 2010 thanks for the response. the wires on the passenger side under the dash has already been hooked. what i've shown you is what i have left ... but there's still too many wires so i'll just trial and error to find out what would start... sigh. Quote Link to comment
sssr20det510 Posted June 15, 2010 Report Share Posted June 15, 2010 thanks for the response. the wires on the passenger side under the dash has already been hooked. what i've shown you is what i have left ... but there's still too many wires so i'll just trial and error to find out what would start... sigh. Ill have to look where my wiper wirering plugs in. You need to strip all the wires out of the 510 engine bay harness that you don't need Quote Link to comment
ztommyx510 Posted June 16, 2010 Author Report Share Posted June 16, 2010 I think i know where the wiper plugs to... it's got a plug, i think. as for striping all the wires that i don't need.. i am still not sure which wires to keep and what not. maybe i'll do that when i get it running (whenever that will be lol.) Quote Link to comment
ztommyx510 Posted June 24, 2010 Author Report Share Posted June 24, 2010 UPDATE! took out the seats and cleaned the interior. will sand down and primer/rust block interior the driver side floor looks rusted, but its solid with welded panel already intact anyone have suggestion what i should use to put down on the floor besides rust proof primers? thanks Quote Link to comment
sssr20det510 Posted June 24, 2010 Report Share Posted June 24, 2010 Sand to bare metal and use por 15 Quote Link to comment
ztommyx510 Posted June 24, 2010 Author Report Share Posted June 24, 2010 ^^ that's a lot of work... Quote Link to comment
ztommyx510 Posted June 27, 2010 Author Report Share Posted June 27, 2010 Update! I used paint stripper to take off the paint... was time consuming, whew! 3 days worth! took out as much as i could to bare metal pics passenger driverside rear speaker panels primer vht rust protection paint trunk primer, then vht wrinkle painted 30 min and it's already starting to wrinkle. need about 24 hrs to cure and wrinkle will show more Quote Link to comment
ztommyx510 Posted June 27, 2010 Author Report Share Posted June 27, 2010 also did the doors and jams. both sides, took pics of just one side. painted the gas tank as well. turns out pretty nice painted some accessories. up close Quote Link to comment
ztommyx510 Posted June 28, 2010 Author Report Share Posted June 28, 2010 ANOTHER UPDATE! finishing up the trunk. wrinkle didn't turn out the way i hoped for. so.. splattered it. turned out much better. 40 years of dust. looks like new again! driver side rust protected! passenger side i do not want to put on dynomat, so should i jst carpet it or use pad, then carpet? Quote Link to comment
ztommyx510 Posted July 2, 2010 Author Report Share Posted July 2, 2010 not really an update... just finish putting all the lines, fuel pump and gas tank back in :) also, i've decided to get dynamat. i figure some dynamat is better than no dynamat ??? Quote Link to comment
NCRmtrsprts510 Posted July 3, 2010 Report Share Posted July 3, 2010 that trunk looks superb! very nice and clean! keep up the good work! Quote Link to comment
ztommyx510 Posted July 3, 2010 Author Report Share Posted July 3, 2010 lol. thanks :) Quote Link to comment
WAGON JON Posted July 6, 2010 Report Share Posted July 6, 2010 Nice, it is looking pretty good! :D Quote Link to comment
ztommyx510 Posted July 22, 2010 Author Report Share Posted July 22, 2010 thanks for the comments guys! not much of an update, but people like to see pics :D this is a mockup of where i want my ECU and power fuse block to be located (under the passenger seat) though not sure if the fuse dist. block will stay like that... wire harness organized to the side for a clean look. finally got my dynamat (fat mat) in. took 3 days about 8 hrs total. whew! a lot of work. if you noticed i also ran speaker/power wires. i'm thinking ahead ;) Quote Link to comment
ANM21977 Posted July 25, 2010 Report Share Posted July 25, 2010 you and I are about on the same thing on our projects. I too am clearing up my wiring on a blk top on my 71 dime. I was wondering what I am supposed to do about the driveshaft. What type of yoke goes on the end of the trans and can we use the 510 shaft at all. What am I to do, please advise. Your ride looks really good man keep up the good work. :unsure: quote name='ztommyx510' date='21 July 2010 - 09:03 PM' timestamp='1279774995' post='328507'] thanks for the comments guys! not much of an update, but people like to see pics :D this is a mockup of where i want my ECU and power fuse block to be located (under the passenger seat) though not sure if the fuse dist. block will stay like that... wire harness organized to the side for a clean look. finally got my dynamat (fat mat) in. took 3 days about 8 hrs total. whew! a lot of work. if you noticed i also ran speaker/power wires. i'm thinking ahead ;) Quote Link to comment
ztommyx510 Posted July 26, 2010 Author Report Share Posted July 26, 2010 thanks for the comment... people on this forum stop coming in and respond (or help out), not like they use to anymore... are you referring to the driveshaft? if so, you can use the stock 510 driveshaft. the only thing you need to do is shortened it. i'd measure it from end to end (from SR tranny to 510)... and then cut off 3/4" more. good luck. let me know how it goes. Quote Link to comment
ANM21977 Posted July 26, 2010 Report Share Posted July 26, 2010 thanks for the comment... people on this forum stop coming in and respond (or help out), not like they use to anymore... are you referring to the driveshaft? if so, you can use the stock 510 driveshaft. the only thing you need to do is shortened it. i'd measure it from end to end (from SR tranny to 510)... and then cut off 3/4" more. good luck. let me know how it goes. Ok I did notice that the shaft needed to be shortened I guess what I really need to know is if the slip yoke on the 510 driveshaft can be used on the sr tranny. I had some difficulty sliding it on there. It doesnt seems as though it slides all the way in, is it a super tight fit? Or do I need a yoke off of a sr tranny? Thanks for any advise you can give me. ;) Quote Link to comment
ztommyx510 Posted July 27, 2010 Author Report Share Posted July 27, 2010 as far as i know, it should fit after it's shortened. ...and you do need to remove the dust shield/boot from the sr tranny. hope that helps. Quote Link to comment
ANM21977 Posted July 27, 2010 Report Share Posted July 27, 2010 thanks ;) as far as i know, it should fit after it's shortened. ...and you do need to remove the dust shield/boot from the sr tranny. hope that helps. Quote Link to comment
78kingcab Posted July 30, 2010 Report Share Posted July 30, 2010 i give ya props...lookn real good...i cant start 2 projects at once ..they never get done..lol...so any way keep it up Quote Link to comment
ztommyx510 Posted August 7, 2010 Author Report Share Posted August 7, 2010 ^^ thanks! no updates yet. trying to find funds to buy more parts :) Quote Link to comment
ANM21977 Posted September 16, 2010 Report Share Posted September 16, 2010 Took a week off to work on the datty. Why do you use a low pressure fuel pump in conjunction with the high pressure? Also why do you need a surge tank. What is its purpose? Also i'm back! anyhow, fast forward to this year... this is where i'm at now. ^^ that intake pipe is temporary only. will be replace by a BOV. I needed it there for start up and testing only. Fuel: warlboro hi flow inline pump and carter low pres. pump. Nissan Z32 Fuel filter and surge tank. if you see something not right, please let me know or if you have a better way of doing it. Thanks! More to come. Quote Link to comment
