ztommyx510 Posted June 9, 2010 Report Share Posted June 9, 2010 Hello everyone, I am new here, but not to the 510 scene. I've lurked around and finally post something. I'm a member from other 510 forums as well but decide this site has the most traffic and perhaps I will get better help. Anyway, enough for the introduction.... I have a 1970 510 I've been working on for about 5 years now. It's my so-called never ending project. At a point I was going to give up on it lol... Here's what I have... I'm very close finishing it... but pics will do the talking. I'd like to finish this project with all of you and would need your help to get it done. I started with this... don't mind the front wheels on backward, it's the guys at the tire shop :) Then my head gasket was on it's way out. Took it to a buddy of mine by the name of Bill Breedlove (some of you may know him) He took my car in and replace the head gasket and adjusted the valves. A week later it wouldn't start. It just cranks but does not fire up. I did everything in the book to see what the problem was.... no success. I decided to just take it apart and look. I found a bolt stuck in one of the valve! I assume Breedlove lost it 'somewhere' lol. Quote Link to comment
ztommyx510 Posted June 9, 2010 Author Report Share Posted June 9, 2010 i'm back! anyhow, fast forward to this year... this is where i'm at now. ^^ that intake pipe is temporary only. will be replace by a BOV. I needed it there for start up and testing only. Fuel: warlboro hi flow inline pump and carter low pres. pump. Nissan Z32 Fuel filter and surge tank. if you see something not right, please let me know or if you have a better way of doing it. Thanks! More to come. Quote Link to comment
ztommyx510 Posted June 9, 2010 Author Report Share Posted June 9, 2010 Anyone know what this is? It's the GREEN RELAY. Don't know to what? It's a modified harness by DGR as well. close up any help would be great. Quote Link to comment
thisismatt Posted June 9, 2010 Report Share Posted June 9, 2010 Well, I don't know how anyone would have any idea really, but "Batt +" YELLOW and "Switched +" RED are normally car head unit (HU)/stereo power colors. Yellow is standby power to the HU (maintain presets, settings) and red is the ignition switched power to the HU. Looks like they just tied it in near the ECU. Quote Link to comment
INDY510 Posted June 9, 2010 Report Share Posted June 9, 2010 I have a the same relay for my fuel pump.......... ( I think ) ........ I am not really shure though Quote Link to comment
ztommyx510 Posted June 9, 2010 Author Report Share Posted June 9, 2010 ^^ at first i thought it was for the fuel pump too, but there was no indication of any kind. so if i can't figure it out by the time i get to fire it up, i'm just going to bypass that. anyway, does anyone know or if anyone in here with SR swap using the stock 510 harness along with the SR harness? thats what i'm doing now for all my lights, wipers, signals, side markers, etc. i've seen other swap using relay board like this one: or even these ^^ these would look nice and clean. Quote Link to comment
sssr20det510 Posted June 9, 2010 Report Share Posted June 9, 2010 The top one is the one icehouse builds, it makes it really easy Quote Link to comment
ztommyx510 Posted June 9, 2010 Author Report Share Posted June 9, 2010 ^^ yes, that's who it was i believe, but i don't know how it works or how it's drawn up... does he sell the kit? whats the wiring to/of? Quote Link to comment
ztommyx510 Posted June 9, 2010 Author Report Share Posted June 9, 2010 Well, I don't know how anyone would have any idea really, but "Batt +" YELLOW and "Switched +" RED are normally car head unit (HU)/stereo power colors. Yellow is standby power to the HU (maintain presets, settings) and red is the ignition switched power to the HU. Looks like they just tied it in near the ECU. actually, it's on opposite ends, just that the harness is bunched up. Quote Link to comment
INDY510 Posted June 9, 2010 Report Share Posted June 9, 2010 Have you seen this thread yet?: http://community.ratsun.net/topic/537-how-to-wire-a-ka-sr-ca-into-anything/ This is the diagram Icehouse posted: Quote Link to comment
ztommyx510 Posted June 9, 2010 Author Report Share Posted June 9, 2010 ^^ reading that thread now... yes i have that diagram. it's what i'm going off on... and i believe there was a similar diagram BUT with only 2 relay instead of 3. i'm going with this current one with the 3 relays though. there were a few color wirings (on diagram) that did not match what i have on my wire harness ok i just read icehouse says 8 wires and it's done.. hmm.... it's the electrical that i'm stomped with... everything else is sourced all over the internet. where's icehouse? i need help wiring Quote Link to comment
sssr20det510 Posted June 9, 2010 Report Share Posted June 9, 2010 I bought mine from him not sure if he has anymore made up, but its pretty basic just go off that diagrahm and you should be fine Quote Link to comment
ztommyx510 Posted June 9, 2010 Author Report Share Posted June 9, 2010 hmm... i'd like some visual Quote Link to comment
ztommyx510 Posted June 10, 2010 Author Report Share Posted June 10, 2010 Anyone know what this is? It's the GREEN RELAY. Don't know to what? It's a modified harness by DGR as well. close up any help would be great. ok, i'm back! been looking thru this site and found out what the GREEN RELAY is. it has 4 wires: 2 black w/ white stripe ?? 1 black w/ pink stripe (fuel pump relay control) 1 black w/ yellow stripe (12v power from fuel pump) nex to that is a green wire w/ yellow stripe (neutral safety switch, according to ratsun) BUT it was labeled start signal? so now, what does all this means? i assume all i need to do was hook up the wires of the +switch and +battery and +start signal? any help would be appreciated. Quote Link to comment
sssr20det510 Posted June 10, 2010 Report Share Posted June 10, 2010 Your going to use the 510 starter signal wire to start the car, you will tap the orange wire off the little plug by the ecu into the 510 harness Quote Link to comment
ztommyx510 Posted June 10, 2010 Author Report Share Posted June 10, 2010 which wire do i tap into the 510 harness? i do see a brown/orange wire near the ecu plugs and also saw a few wires from the 510 harness used for the starter, alternator and battery. if you have any visual (pics) please post them up. it will help greatly as i'm more of a visual person :) Quote Link to comment
sssr20det510 Posted June 10, 2010 Report Share Posted June 10, 2010 Don't have any pics, there is a wire on the 510 harness that signals the starter you keep that wire I think its black with white or yellow stripe. Then on the sr harness there should be a plug that is right next to the ecu plug you take the orange wire oit of there and tap it into the 510 starter signal wireI Quote Link to comment
ztommyx510 Posted June 11, 2010 Author Report Share Posted June 11, 2010 ^^ when those two are tapped together, this is going to go to the starter? it would help if you could take some pics. btw, i've read thru your buildup thread, nice build! Quote Link to comment
ztommyx510 Posted June 11, 2010 Author Report Share Posted June 11, 2010 according to this diagram: how is this RELAY wired up? am i using the right relay? can someone draw out lines (wires) thru similar to the diagram for me? would greatly appreciated. Quote Link to comment
thisismatt Posted June 11, 2010 Report Share Posted June 11, 2010 according to this diagram: how is this RELAY wired up? am i using the right relay? can someone draw out lines (wires) thru similar to the diagram for me? would greatly appreciated. Quote Link to comment
ztommyx510 Posted June 11, 2010 Author Report Share Posted June 11, 2010 ^^ nice! so the (pic) the two silver plug are the "coil" seen on the diagram (86 + 85)? and the copper plug on the relay are open end (87 + 30)? thanks again.. Quote Link to comment
thisismatt Posted June 11, 2010 Report Share Posted June 11, 2010 (Note: The relay you pictured does not have 87a, which many do) Quote Link to comment
dennis Posted June 11, 2010 Report Share Posted June 11, 2010 (Note: The relay you pictured does not have 87a, which many do) Looks like a sad monster with a mole. Quote Link to comment
dennis Posted June 11, 2010 Report Share Posted June 11, 2010 you can still use that relay. 87a is not going to be used in this application anyways. Quote Link to comment
