LenRobertson Posted June 2, 2010 Report Share Posted June 2, 2010 I know I've read this before, but can't find the info now that I need to know. Can I get away with hanging a square port exhaust manifold on a round port smog head? And does if matter which manifold gasket is used - round or square? Len Quote Link to comment
e_racer1999 Posted June 2, 2010 Report Share Posted June 2, 2010 Yes. Most gaskets are square, also. Remember, you can use a square on a circle, but not a circle on a square. Or a triangle. Or even an elephant. 1 Quote Link to comment
izzo Posted June 2, 2010 Report Share Posted June 2, 2010 Yes. Most gaskets are square, also. Remember, you can use a square on a circle, but not a circle on a square. Or a triangle. Or even an elephant. Can to use an elephant :rofl: Quote Link to comment
sick620 Posted June 2, 2010 Report Share Posted June 2, 2010 Yes. Most gaskets are square, also. Remember, you can use a square on a circle, but not a circle on a square. Or a triangle. Or even an elephant. im running an elephant port it works fine. :lol: Quote Link to comment
Gensaiken Posted June 2, 2010 Report Share Posted June 2, 2010 wait.. how can you use a square port exhaust manifold on a round port exhaust hole? Is the round port exhaust hole smaller? I'll have to try this out. :blink: Quote Link to comment
hang_510 Posted June 2, 2010 Report Share Posted June 2, 2010 im running an elephant port it works fine. :lol: only when used in conjuction with the elephant oil cap and elephants in a triangle... Quote Link to comment
Gensaiken Posted June 3, 2010 Report Share Posted June 3, 2010 my only question is, wouldn't using the square on a round create an obstruction for the flow of the exhaust? Is there any advantage of using the square port exhaust over the round? Is it just a matter of better flow? or any extra torque by using a Y-pipe? Quote Link to comment
izzo Posted June 3, 2010 Report Share Posted June 3, 2010 no, round into square is fine. It will allow free flow. Square into round, the 4 corners in the square are being "blocked" if you will creating resistance since the hole is rounded. Quote Link to comment
Gensaiken Posted June 3, 2010 Report Share Posted June 3, 2010 no, round into square is fine. It will allow free flow. Square into round, the 4 corners in the square are being "blocked" if you will creating resistance since the hole is rounded. hmm. Well I have both available to me. I kind of like the standard square port.. Although now I need to find some one who has a spare 510 y-pipe. Quote Link to comment
banzai510(hainz) Posted June 3, 2010 Report Share Posted June 3, 2010 Nismodr(Ed hanson) had a made a flange for the 510 ex manifolds. so you can make your own Y pipe or have the shop make one and make it into a 2inch collector than the small stock size( 1 5/8s) Quote Link to comment
e_racer1999 Posted June 3, 2010 Report Share Posted June 3, 2010 The elephant head port is very rare, they only came on 1956 510s. Quote Link to comment
hang_510 Posted June 3, 2010 Report Share Posted June 3, 2010 need to find some one who has a spare 510 y-pipe. got one. i can try to make time to chop it off before canby :mellow: Quote Link to comment
Gensaiken Posted June 4, 2010 Report Share Posted June 4, 2010 got one. i can try to make time to chop it off before canby :mellow: Cool, I think I'm going to pass on the square port on the 620 at the moment but I still want the y-pipe for a 510 project. PM me and let me know what you'd want for it. Quote Link to comment
LenRobertson Posted June 5, 2010 Author Report Share Posted June 5, 2010 Thanks everyone for the variety of information. I'll explain why I asked the original question. Maybe someone can learn from my ongoing saga. I got stuck in my L20B rebuild trying to decide on pistons, rods, CR calculations, other decisions. The city here was making noises about enforcing the junk car ordinance, so I got paranoid, and wanted to get my 510 running soonest. I bought a used complete L20B for $85 - manifolds and carb on it, just drop it in and I'd be running. It hasn't been quite that quick and easy (what ever is?). The engine is late enough to have round port exhaust, and I could use the manifold by changing the pipe on the car. But one of the three studs in the manifold where it bolts to the pipe is broken. I've taken the manifold off, but have my doubts about getting the broken stud out. At this point, it seems easiest to use on of my 3 or 4 square port manifolds that will bolt up to the pipe already in the 510. It sounds like I may be able to do that, at least to get by for awhile. The really exiting news - I haven't been crazy buying up elephant oil caps at Pull n Save. I suspected they have magical properties, but wasn't sure. I may hang a second one from the rear view mirror, for extra magic elephant power. Now if I can find some of that Elephant beer, do I add it to the oil like you do ATF when you want to clean stuck lifters? Or in the gas, or in the mechanic, or some in all three locations? Len Quote Link to comment
