  • Replies 5
#1, is the L18 and L20 block the same > NO, L20 blk is taller
#2, will a L20 bolt in a 1974 620 L20 came from 1979 620 > YES
#3, will disk brakes and front suspention from 1979 620 bolt in to 1974 620 > NO, not a direct bolt on.
you can find lots of answers to questions by using the search button which is at the top of every thread page. GL with your project... :)
Yes it will. The extra 20mm or 2cm (3/4") height is found in the cylinders just below the head. The rest of the block is identical dimention wise. Be sure to use the L20B flywheel as it 6 bolt mounting the L18 is 5 bolt. In other words the L18 flywheel won't fit the L20B.
Just to be safe get the L20B motor mounts. The L18s will fit, but the L20Bs may position the motor slightly lower to clear the hood.
The L20B will have an internally regulated (IR) alternator so grab and keep it for later. Use the L18 alt for now until you have time for this very good up grade.
The L20B also has an electronic ignition (EI) which is far superior to the L18 points one. Again, run the L18 distributor until you can swap it in.
you can find lots of answers to questions by using the search button which is at the top of every thread page. GL with your project... smile.gif
will a ka24 fit in the 74 datsun 620 how much mod. is needed
Welcome to Ratsun Marco. Sounds like you need to spend some time in the FAQ'S section. It is a "sticky" in this section. The stickies that are in the appropriate sections are filled with some great info for us all. Check it out.
Have any pics of our truck?? Again, welcome.
